How to make a bedpost?
Bob Fawcett
>Looking for information on making bedposts. I found an article by Nick Cook. He says to start with the lower half of the post and begin with the "lamb's tongue". Can someone tell me what the lamb's tongue is?
Looks like I need some more basic information. Any good sources?
Thanks
Re: How to make a bedpost?
Phil Joines
>If you want a video get Ernie Conover's "Turning for Furniture" his other video "Turning Furniture Spindles" is a cut down version of the first.
Dave Peebles Lyons, Ohio!
>Hi Bob,
I have generally understood this to be the point where the bedpost goes from the square to the round... or where the turning begins.
If you do a google search, there are some examples of this. But many of the photos shown have a little carving involved. On the few that I have done, I used a skew on the transition area.
Best wishes,
Dave
Bob Fawcett
>Thanks Dave.
I thought that was the pommel. I am still confused. Here is the culprit.
"I like to turn the bottom half of the post first. It gets the pommels and lambs� tongues out of the way and you will be able to go ahead and drill the mortises before turning the upper portion."
I think I saw a video clip of turning a pommel on the WEB somewhere, but I can't find it now.
A Couple of Sources
Jim Shaver - Oakville, Ontario
>Hi Bob,
Theer are two sources of information that come to mind on turning bed posts.
One is a Taunton Press publication called Beds and Bedroom Furniture. In that book there is an article by Doug Mooberry and Steve Latta on a variety of bed post designs.
Also in the same issue is another article by Philip Lowe on turning a Sheraton bed post, it is well writtn with details.
A second book I like is another Taunton Publication called Period Furniture Details by Lonnie Bird.
In this book he devoted a section to making Pencil Post design bed post, he details in that article how to hand cut a Lamb's Tongue feature on that post.
Hope that helps..
take care,
Jim
Re: A Couple of Sources
>A lamb's tongue is not a turned effect. It is a design detail that terminates the chamfered corners of the a square portion of the bed post. In other words, it is a transition between a square and on octagonal cross section. It is ogee shaped (as opposed to a flat ramp or a cove shaped ramp), and is cut with a chisel. The cut starts steeply at the corner of the square portion, then flattens out out before turning steeply again to meet the flat of the chamfer.
Taunton's photos are indecipherable. If you have a high speed internet connection, try Woodsmith for an excellent streaming video of the process.
http://www.woodsmith.com/issues/153/videos/a-lambs-tongue-chamfer/
Thanks William, exactly what I needed
Bob Fawcett
>Thanks William.
Thats exactly what I needed. I googled for lamb's tongue and got very little.
Looks like I need to order some back issues of Woodsmith.
