a little practice goblet
Keith Tompkins
Keith Tompkins
>I like to practice before I turn something, just to warm up. This is a practice piece made from a scrap piece of holly, 2.5" tall. The bowl was pretty thin, so I set a light above it to show the translucency. I used my newest home-made tool for the captured ring. Again, camera acting up, best I can do for now.
These practice pieces let me play around with different shapes and proportions.
Re: a little practice goblet
georgetroy
>Beautiful job Keith. You captured all it had to give. Thanks for showing. GT
Jim King
>If everyones practice was like that there would be no need for the forums.
Keith Tompkins
Keith Tompkins
>Thanks George! I appreciate you taking the time to respond...any critiques are welcome.
Keith Tompkins
Keith Tompkins
>Thanks Jim....fortunately, you don't see the ones that explode!
GaryG in MD
>Keith,
Cute little goblet. It looks much larger. (That's a compliment!) ;-)
Would you care to share the shape and construction of your new captive ring tool? Is it a dental tool type thing or something different? Do you use it for both sides of the ring? etc.
Gary
GeeSeaWhy
>Just to warm up? That would take me all day! What degree of finishing do you aim for on a practice piece like this - is it ready to sand, a bit rougher than that, fully sanded and ready to finish?
Graeme
Keith Tompkins
Keith Tompkins
>Hi Gary, my new tool is something I've been contemplating for a while and finally made it. I took a keyless chuck by Proxxon, and adapted it to a threaded rod. I had to buy the 6x.75mm die special order to create the threads. I then mounted the rod in a wood handle.
The idea is, now I can change the cutting tool quickly, from a drill bit to a cutting tool, to a sanding mandrel, etc. The captive ring tool is made from an allen key, sharpened on both sides. It cuts both sides of the ring. The allen keys fit into the proxxon chuck, so I don't need a new handle for each size.
I would take a photo, but my images are too fuzzy...new camera soon, I hope.
Jim Shaver - Oakville, Ontario
>Hi Keith,
That was just warming up?
I like the idea of getting " warmed up" prior to going for the work that you want to keep....I should think of that approach more often.
Take care,
Jim
Keith Tompkins
Keith Tompkins
>Hi Graeme, This could get a bit involved. I feel practice is a very important part in ANY craft, art, or even sport.
When I produce a practice piece, I usually don't have a set goal in mind as to what the piece will look like. I really focus on technique...it may be a new technique, or a new tool, or simply a way to refine an old technique. I always consider form however,and analyze each practice piece. I won't let myself produce an intentionally poor piece, as though I am just going through the motions. I try to do my best.
In the case of the goblet, I was trying out a new captive ring tool. I tried it, went back to the grinder to modify it, tried it again in an attempt to perfect the design.
I consider practice an essential part of what I do...I will practice a gouge or skew technique until it becomes second nature. When I really NEED a certain technique, I KNOW I can do it. Therefore, it's important that my practice pieces are well done...I really push myself. The goblet I posted is finish sanded, although it didn't require much...by refining my cutting techniques, I can produce a smooth clean surface that needs little or no sanding. By constantly practicing, I have cut my time to produce a goblet from over an hour or so to about ten minutes. Yet, the quality has IMPROVED.
The more I practice, the better my work seems to get. Thinner walls, smoother finish, better shapes and forms. The way I see it, if my practice pieces keep improving, so will my real pieces.
Jennifer@Indy.USA
>Nice Warm up Keith :)
I'd hate post my "warm ups"!
Jen
Thanks Keith; great idea.
GaryG in MD
