jet mini
jet mini
jet mini
bob davis
>thanks to bruce and brandon for info on reversing the jet mini.now, if someone would come up with away to get it down to zero rpm on all belt settinga that would be great..bob davis
Re: jet mini
Re: jet mini
Bob Lemon, Sacramento CA
>Our Jet mini is at zero rpm most of the time. ;)
Re: jet mini
Re: jet mini
>Bob I still have one of the power supplys for the jet mini. I'll check the power dial. It's probably a potentiometer. You may be able to simply get another one or add a resister in series or parallel to change output. I'm teaching a workshop this weekend so I probably won't be able to check this out until sunday night. Maybe someone else will with electronic knowledge and a mini will see this and help you out before I can.
Re: jet mini
I'm one of the lucky ones
Don Henthorn
>who followed Mark Kauders instructions to get the Vega DC motor which was sold a while back. It is really great to be able to slow the lathe down all the way to 0 rpm if you want to. Today I had it turning slow enough that I could spray lacquer on a piece as it turned.
Re: jet mini
Re: jet mini
Russell L. Babbitt Jr.
>One option would be to replace the Jet controller with another such as those available from ebay. I drive my two Vicmarc minis with such a controller. This may not be a cost effective way of doing it, some research would have to be done.
Re: jet mini
Re: I'm one of the lucky ones
bob davis
>you are ! wish i had known about that.guess no more available..you have your lathe preforming as it should...
Re: jet mini
Re: jet mini
bob davis
>thanks, john will wait to hear from you
Re: jet mini
Re: jet mini
Eddie Pacheco; San Jose, Ca.
>I think John Lucas' method, with the addition of another switch, would be the way to go. You would switch an additional resistor in series with the center leg of the speed pot. to get an additional speed range. Alternatively you could add a 2nd potentiometer, also via a switch to the center leg of the normal speed pot., and switch this in and out of circuit to gain more speed combos. A lot of the motor controller have additional trim pots. that are used to match the motor controller to the motor and motor torque, and speed ramp up may be inconsistant at lower than the normal controllers speed setting.
