We value your privacy.
So I tried to do the taper thing some of you suggested the other day. I went to the library and picked up Conover's Turning for Furniture book too.
It didn't work. My work piece kept popping out. Maybe the taper wasn't long enough(?). I saw in the book about making the collet thingy. It shows making a compression ring. Unfortunately, it doesn't explain how to make a compression ring. Just turn the ring then drill out the hole?
I know. I know. I can run over to Rockler and pick up the knobs and Shaker pegs. But I enjoy the aggrevasion... :)
>Joe I'll try to describe it better. Ideally you take a piece of wood that is about 3" in diameter and 4 or 5 inches long. Mount it on the faceplate so the grain is running parallel to the bed. Turn a tenon about 1" in diameter that is about 3" long. It can taper and get larger back toward the headstock but you need about 1 1/2 inches that is around an inch thick. Turn a shallow depression about 1/2 from the end and a little wider than the hose clamp you will be using.
Now drill a hole the same size as the tenon on your shaker peg. Then take a bandsaw or hand saw and cut a bunch of slots down the length of tenon. I usually make 4 cuts which leaves me 8 slits for compression. Now put the hose clamp on, put your shaker peg tenon in and tighten the hose clamp.
When you turned the morse taper you may not have made it accurately enough. More accuracy and possibly more length would help. Vibration is a problem with this style of holding a piece. You need to take light cuts and possibly support the work with your fingers form the backside. I had all of my students support the loose end with the tailstock up until the last few cuts. I think the tailstock pushing and the vibration from cutting probably seated the morse taper more firmly. I don't remember anyone in the class having trouble with the piece coming out. they had lots of other problems but I don't think that was one of them.
>Try the taper thing again. I use a taper about an inch long. Drive it into the shaft with a mallet or heavy block of wood. Bring the tail stock up to it and apply light pressure. If you have a point center on your tail stock, you can split the piece with too much pressure. If you have a little cup center on the tail-stock, press harder. Turn your peg, leaving an 1/8 or a 1/4 at the tail-stock end. When everything else is finished, cut the waste down as much as you can and then back the tail stock away and finish the end. This way the tailstock holds it into the taper until the last minute.
>Do the entire turning except the very end where it contacts the tailstock and as much of that as possible. Back off the tailstock and using a small, swept back grind spindle gouge make the parting cut and round the top of the peg at the same time. You can use a skew once you�ve had some practice with one.
On the compression chuck, rather than a hose clamp I use the inner race from an old bearing. Check an auto repair shop. Any stiff metal ring with rounded edges will work. Size the tennon to fit with a bit of taper. It doesn�t have the big lump of metal sticking out.
>Joe I think I may have a photo of the kind of home made collet that we are talking about. I'll try to look it up when I get home and post it if I do. I shot a photo of one I made to put in American Turner tips pages but I don't remember if Carl used it or if I saved it.
>Joe Here is one I made for a 1" tenon. I made it fit my chuck but you could easily make the wood bigger so that it would fit a faceplate. If the screw clamp seems dangerous you can put masking tape around it. You can also taper the tenon more and use a steel ring that you drive up the taper to squeeze the collet together.
