Re: Jet Lathe Question
>It's not toast. The JET live centers do not have sealed bearings, and dust and shavings can get into the bearings from either end. You can disassemble them, clean the bearings (naphtha or acetone work), relubricate (20 weight non-detergent motor oil works) and reassemble. That will probably get it up and running again. Then, you will probably want to develop a strategy to keep dust out in the future. Rule number one is, whenever possible, to operate it and store it with the removable center tip in place. Rule number two is to oil a small piece of paper towel and insert it in the hole in the morse taper to keep dust from getting in that end. If, when you disassemble the bearings, you find that they are worn out, they can be inexensively replaced. Sealed bearings are more expensive than the originals, but might be worth the extra cost to you, depending on how far away your nearest bearing dealer is. If you don't feel up to doing the repairs yourself, you can take it to any JET service center or to any machine shop that sells bearings. Even if you get another live center, you should fix and keep the original JET as a backup.
