Reversing switch
Reversing switch
Reversing switch
Frank
>I have a Jet midi with variable speed. I am interested in installing a reversing switch for sanding purposes and some minature turning. Does anyone have any information on this. I contacted Jet and their answer was, "we do not offer that feature on the Midi lathe". I am just wondering what the downside to this is and if none, does anyone have good instructions to work the issue. I have a double throw/double pole switch but no knowledge of electrical stuff. Any help would be greatly appreciated. Thanks.
Re: Reversing switch
doubtful
T Daniel
>Unless the motor was wired to be reversible you cannot do it with a switch. My guess is that this motor cannot be reversed.
TD
>Frank I can't remember exactly how that lathe is wired but it would be easy enough to find out. Open up the box and swith the 2 wires that go to the motor, white and black I believe. If the motor reverses then it will be quite easy to wire this up. I think it does but It's just been too long since I played with the wiring.
Phil Powell
>Frank,
I put a reversing switch on my Jet Mini and It was easy. The instructions
are on the web site I have listed here. Reversing your lathe should be
similar.
http://www.frontrangewoodturners.com/
Bill Neddow
>Excellent piece of informtion. Now, does anybody know if this can be done with the older Jets (non-variable speed)? I know I could take it apart and reverse the motor wires -- but with my luck I would burn out something in the motor if I try. Besides, I am lazy and a little scared of electrical stuff.
Phil Powell
>Bill,
I've been told that a reversing switch only works on a DC motor. The Jet Mini
variable speed lathe has a DC motor. There maybe a way to reverse an AC
motor but I'm betting it's a much bigger job.
>I had a lathe when I was 16 years old and made a reversing switch for it. I wired a two prong plug (like for a table lamp) on it and put a two prong receptacle on the stand be side it. The receptacle was also wired into the two wires you are discussing on the motor. When I wanted the lathe to run backward, I unplugged the plug, turned it around and plugged it back in. Crude but effective. Used it that way for more than thirty years. When I sold the lathe the guy was thrilled with it and insisted on setting it back up.
>Phil You can't reverse the motor on the non variable speed motor.
Bill Neddow
>Thanks, John. I suspected that -- and you have saved me an evening's work and some puffs of smoke from my motor, which would then leave me worrying for months about what damage I have really done.
Russ Babbitt Jr.
>It's been answered already but since I did some research and found this I thought I would add it to this thread. Using this method is for DC motors only......
http://www.eleinmec.com/article.asp?12
dave schaefer Fairbanks AK
>Some capaciter/start motors can be wired with a reversing swich..I have such a 120/230 1725rpm Dayton 1 hp on an old Atlas lathe and find the reversing feature handy... ck the wireing diagran on the motor...if lit can be wired for CW/CCW rotation then it can be exte4nally swiched to reverse... may take a motor shop to help...good luck ...DS
Frank
>Hey guys,
I really thank you all for your input. This is really great. I think I might even be able to do this...the guy that hesitates to change the batteries in a flash light. Many, many thanks for the help.
Ron Menninga
>I am supprised that no one has suggested simply putting a twist in the belt. I have a Jet mini non-VS and when sanding I just loosen the adjustment, reach into the side, put a twist into the belt and put it back on the spindle (lowest speed only as it does put some stress on the belt). This can only be done on models like the Jet mini that has easy access to the belts. Really easy.
