Jet Mini Spindle Lock
Doug Reynolds in Seattle
>Has anyone devised a way to lock the spindle on a Jet mini-lathe? Something that does not require two or more people or, more than two hands at the same time.
Re: Jet Mini Spindle Lock
Carole Valentine
>Insert the knock-out bar into one of the two holes in the spindle and let it rest against the bed.
Phil Joines
>Before your post I haden't considered a need for one. As Carol said I've always just used the rod.
Since I can't resist trying to make these kinds of things I figured to give it a try.
My Jet is an older nonVS model. There are two 10-24 tapped holes on the rear edge of the headstock I have no idea what they are for. I made the piece in the pic from hard maple. Didn't realy measure anything except the diameter of the spindle boss which is 3". The other mounting hole was placed in what looked like a good place. Cast iron is easy to drill and tap. The hole is for the knock out bar.
The bar realy should be supported closer to the spindle, but it works.
Next time I break out the metal working tolls I might do one in steel.
Phil Joines
here's the metal one
Phil Joines
>The base is a piece of 3/16" x 2" flat bar. The socket for the knockout bar and the spacer are 1/2" square tube. The spacer needed to be flattened a bit with the hammer to get the spacing right.
The welds are a bit crude. The only rod handy was way too big.
Re: here's the metal one
Jennifer@Indy.USA
>Very clever Phil. This would come in handy.
Jen
>Phil I'm still working on my Jet mini upgrade ideas. This or something like it will definitely be included.
