Beal Buffing problem
Dennis Taylor
>I have a problem and not sure why....I turned a bowl and a few other items, applied 3 coats of lacquer to them allowed to dry overnight...used the Beal system with Tripoli, White Diamond and then wax....don't know if I buffed thru the lacquer finish, but I get white streaks, and it looks like the lacquer has been removed, can someone recommended maybe what I did wrong, and 2ndly can I just re-apply the lacquer to the bowl and start over, or isn't it that simple now?....tks in advance...Dennis
Re: Beal Buffing problem
Re: Beall Buffing problem
Ed Moore
>Dennis,
I would take some lacquer thinner and wipe all the finish off and let it dry overnight. Then, apply three LIGHT spray coats of lacquer and let that dry overnight.
Then buff LIGHTLY, and do not let heat build up. You may have been too aggressive with the white diamond and the lacquer melted a little. Remember, you are just polishing the surface.
Ed
Dennis Taylor
>Ed, I have taken your advice, used lacquer thinner, wiped the bowl, actually a lidded box, wiped down the whole box, and will let dry overnight, and then re apply the lacquer, 3 coats and allow to dry, I guess maybe that was it, just to much pressure and burned thru the lacquer finish, I hope....tks for advice, not much on the finishing...the box looked great, until I buffed it, then white lines...tks again...will post how it comes out...I will post pic, never done that before either...Dennis
>Dennis there was a discussion of this problem Below. Look down for the Power Buffing Thread.
Re: Slow down, the lacquer...
JamieDonaldson
>... takes longer than overnight to cure and harden, especially this time of year. I often have to wait a week for the finishes to dry during winter weather conditions.
Ric Taylor
Ric Taylor
>Dennis,
Lacquer is a soft finish, and it's not difficult to buff through it. I recommend that you don't use the tripoli, just use the white diamond. Keep the rpm down around 700, use a light touch, and take your time. You should be rewarded with a smooth shiney finish.
Ric
