Have a question? Ask Woody!
Flat guy with a question
Joe in a Cleveland suburb
>Hi folks.
I don't wander over here often (from the flat world that is), but I have a question.
I've had a Jet mini with extension bed now for a couple or three years. I rarely use it. I plan to some day but just haven't gotten to that point yet. I need to make some Shaker pegs for part of a project; a peg board to hang a cabinet on I'm pretty much done making. For the heck of it I put a piece of scrap Cherry between the centers a few days ago to give it a shot and to see if I remembered how to turn this thing on... :) It worked fine.
Here's my question though. I know I could go out and spend lots of money and buy all kinds of toys for this little lathe but I don't want to. It occurred to me it would probably be easier to make these things if the stock wasn't between centers. I thought it would be easier if the stock was in one of those chuck thingy's. But I don't want to buy one(!). The problem I had was getting a nice clean rounded end, not the tenon end. So I thought it might be a good idea to take a piece of thick scrap - maybe a couple inches thick, make it roundish, drill a hole in the center, attach it to the face plate thingy, stick my stock into the hole (which would be centered btw), and use a screw to fasten the stock in the hole from the side. Whew. Hope that made sense.
I'm sure this is not a new idea, it's just something that seemed logical. Is it?
Thanks,
Joe
Re: Flat guy with a question
Ron in Drums PA
>It's called a jam chuck.
I use MDF for the jam chuck.
>Of course you could always get an inexpensive collet chuck...
(Beware the turning side, Joe - they will lead you astray and make you buy all sorts of expensive toys - uh, tools.)
JL can you
>JL. Can you give me an example of "an inexpensive collet chuck"?
Thanks,
Joe
Re: JL can you  *LINK*
Ron in Drums PA
ebay
Don't do it!
Mike Schwing from Md.
>All I wanted was to make ONE table leg - for the table pictured below. ONE LEG. Thats all I wanted. One simple table leg. The table below was also the last piece of furniture I ever made. Damned wood lathe gets under your skin. Go buy your shaker pegs! Otherwise, your table saw will be covered over in plastic and serve as a place for you to paint/wax your freshly cut turning blanks.
Re: JL can you
Ron in Drums PA
>BTW I'm not the person selling this.
WOW; what kind of wood is that? (NM)
OB OBrien In Pensacola
Quilted/blistered African Makore
>No matter how wild looking it is, it is NOT WORTH IT. Most horrible stuff I've ever worked with. Apparently, all humans are allergic to it. Just a tiny breath of dust will send a person coughing, hacking, sneezing and wheezing. Plus, all sensitive skin areas - insides of elbows, wrists, knees, even my waistband broke out into a rash while working with the stuff. Horrible tear out, needed to use hand tools exclusively for finishing, and IIRC, I didn't even use much sandpaper on the whole thing for fear of more dust. Just handplanes, and scrapers mostly. Actually had to plane perpendicular to the grain in order to prevent tearout. Never encountered a wood like that before. Hope I never do again. This is my bedside table now. Looks great, but not worth it!
>A collet chuck is a good thing if you are doing lots of pegs and similar stuff. You could also get something like a Oneway Talon chuck (but those are more expensive). As Mike said, don't do it - look where it got him...
Collet chucks
Re: Flat guy with a question *LINK*
CJ in MN
>You've already got a jam chuck Joe. Turn the end of your turning blank down to the size of your morse taper and seat it in the drive end of your lathe. Attached is a link to Alan Lacers website. The article doesn't pertain to your question but it has a picture of how he drives smaller stock in his lathe. Good Luck
http://www.alanlacer.com/articles/speed_zone.html
Pascal Oudet
>Joe, before chucks existed, a very popular way of holding end grain pieces on the lathe was (as still is) what we call here a "goblet". it's just a piece of round steel, like a thick pipe, one half is threaded to go onto your lathe, and on the other part is like a pipe, you just turn a slightly tapered tenon on your blank and hammer the wood in the pipe. it works very well. probably a machinist could do that for you. I don't have any picture here, but in the last Woodturning magazine they feature a Japanese turner who uses this kind of accessories.
Pascal
>Joe your system works but I turn a wooden chuck. Fasten an endgrain piece of wood about 5" long or so to your faceplate. Drill a hole in the center to fit the tenon size of your shaker pegs. Now turn down the outside of the blank until it's about 1" in diameter. Cut about 4 to 8 slots back from the tip. Now you can insert your shaker peg blank and tighten a small hose clamp around the end of your wooden chuck.
Doesn't work as well as a good chuck or collet but works well enough.
Another method is to simply glue the blank to the wasteblock. Then turn it. When your done part it off clean up the glue blank and glue another one on. I use 5 minute epoxy. It's slow but it works great.
I didn't have a chuck for a long time and came up with all sorts of ways to get things aligned and glued onto a blanks for turning.
Phil Joines
>Here's one way to do it without much expense.
Go to the link and order the "Collet, (size), 2MT" for the tennon size you want. You'll also need a piece of 3/8" threaded rod, nut and washers to pull the collet closed. Fine a good quality open end wrench in that size. Grind the shorter jaw of the wrench into a cutting edge.
Put the pieces between centers. Rough size the piece with your favorite roughing tool. Rough size the tennon area. Keep a bit of pressure on the wrench's long jaw as you cut the tennon to size with the short one. Install the collet. Put the piece in the collet and cut it.
It'll cost about $20 to get set up.
http://www.littlemachineshop.com/products/product_search.php?critFast=collet&SearchBy=1
>Phil is right. I have a full range of these things that I picked up at the flea mkt. All the ones I have are threaded for 5/16 so I just bought some all thread and made by draw bar.
Gee, I thought the Shakers used that all the time!
Craig Daymon
>;-) Great looking table. Must have been a nightmare to turn trying to avoid the dust. Amazing it was your motivation to keep turning.
-Craig
>Joe I completely forgot the simplest solution. I used it in my ornament class. Mount the wood between centers and turn about an inch long #2 morse taper on one end. Then drive it in the headstock. Start your turning between centers and then pull the tailstock away and finish is off. This is works extremely well and is very easy to do.
I just had the students measure 2 marks on the morse taper 1" apart. Use a parting tool and cut down very close to these diameters. then remove wood until you have a taper between the two points. turn away most of the smaller portion or cut it off later. it doesn't have to be exact because the wood will compress to fit the taper. you won't believe how good this works.
I used it in a beginner class on turning ornaments because we didn't have any chucks. Every one of the student's had success with this.
>Wow. It's that simple? Just create a #2 morse taper on the end of the stock and tap it in, eh? Why didn't I think of that?
I suppose I could just try to duplicate the taper jobber on the spur thingy that's in there now right?
Thanks a ton everybody.
Joe
>Joe OK now we've tackled that, do you want to know how to turn an offset tenon on the shaker peg so that you can rotate it a align it perfectly? I made a gun cabinet for a guy and even though I drew all the gun patterns I knew it would have to be fine tuned to get the barrels of all the pistols perfectly level. The guy lives in Atlanta so I had to build the piece and then assemble it when we got to his house. I turned offset tenons on all the shaker style pegs that were to hold the guns. When we put the guns in, I was able to "micro" adjust each peg by rotating it, until the barrels were all level. Then I locked them in place with a screw from the back.
I mounted it between centers and turned a 3/8" tenon.
Then I remounted it between offset centers and turned the shaker peg. I carved away the tenon on the front end and cut the other tenon off using the bandsaw to leave just the offset tenon and the peg.
Unless you're profecient...
RevDoug
>buy your pegs. Usually you can buy them so much cheaper than you can turn them that it really doesn't make sense to make them.
Turn 'em round,
Measure No 2 Morse taper
>Make a gizmo to test the size of your wooden Morse taper. Take a stick and fasten a block of wood on it crosswise. Use the spur center or anything else that fits the taper in your lathe as a pattern and lay it beside the block. Fasten another block on the other side of the tapered shaft just snug. Now you have a feeler Gage or "wrench" you can slip on your turning as a pattern. I don't feel I have explained this well, a picture would be worth a thousand words. Its dirt simple once you get it.
And yes, this is a great way to attach small object to the lathe. Use it all the time for icicles. No chuck in the way, nothing to buy.
I also agree this might be a better thing to buy than make. Making a bunch that are identical is probably daunting for a newby. Easier to buy them.
