Jet 18" Bandsaw Bearing ???
Nick Stagg
>I've had the bandsaw for a little over a year and I've replaced the upper guide bearings once and the lower guide bearings twice. Is this a common problem with this saw? I don't over use it and keep it as dust free as possible. The bearings on it now are sealed.
I use Suffolk skip tooth blades, and, yes, a lot of my wood is wet
Unless I'm doing some thing wrong, I don't see how the lower guide bearings can be accurately adjusted with out removing the table.
I could use some feed back.
Thanks, Nick
Re: Jet 18" Bandsaw Bearing ???
Benn there, done that...found a solution
Peter Teubel
>I have a Jet 20" and had the same problem. I have 10 bearings on the guides. 5 siezed up within the 3 months of use. I replaced ALL the stock shielded ones with SEALED ones and have had no problem for 2 yrs. You've done that so you're already ahead.
Lower guide adjustment: Drill two 3/8" holes thru the top of the table directly above lower adjustment screws (the table is rather cheap cast iron and drills very easily). Use a long shaft allen wrench to access them from ABOVE the table.
JKJ in East TN
>Nick, Evidently there are sealed bearings and there are sealed bearings. I just bought some from Iturra Design (888-883-8064) for a 14" bandsaw which they claim are better sealed using rubber to keep out the fine dust. You might give them a call and see if your bandsaw uses the same bearings.
Keith Tompkins
Keith Tompkins
>Hi Nick, be sure the new bearings are not adjusted too tightly. When adjusted properly, the rear guides should NOT spin while not cutting, but spin instantly when wood contacts the blade. This will prolong their life greatly.
The side bearings can be set with a thin piece of paper between the bearing and the blade on each side, making sure to apply even pressure against each bearing. They should spin at the same speed when the saw is running.
>Had my JET 18 for 5 years before the bottom thrust bearing seized and died a noisy death. It was, however, the very excuse I was waiting for. The new set of Cater guides arrived 2 days later. What a difference in both thrust and lateral control performance! I was concerned because others have commented that they were good but noisy. Suspect it's an adjustment issue because mine are very quiet since I set them a mil or two away from the blade when under tension.
Mark
Thanks for all the advice
Nick Stagg
