We value your privacy.
I am safety conscious and I do wear a face shield and safety glasses and now have a dust collection system, but I can't bring myself to use that big old guard. When it is down it just seems to get in the way.
So far I have kept it in the up position and clamped a swing lamp to it and bungied my dust collector hose to it.
Unless you are looking through the guard it is not
T Daniel
>protecting you. If a bowl comes off and is sailing away from you why would you want to turn it around and send it back into your face?
The guards only protect someone else in the room, they do little to protect the operator. It is a liability thing and is there to protect the manufacturer of the lathe, not the operator of the lathe.
Re: Unless you are looking through the guard it is
Bill Dotten
>THE USUAL RESPONSE IS THAT YOU SHOULD DISPENSE WITH IT.
I HAVE BEEN BANGED ON THE HEAD AND I HAVE SEEN HOLLOW FORMS BLOW UP. i KEEP IT AND I USE IT ON LARGE UNBALANCED BLANKS, ON PUNKY WOOD AND ON WOOD WITH SUSPECTED SPLITS. WHY BE A MACHO GUY IN THOSE SITUATIONS. NO ONE WILL SEE ME USE IT OR CALL ME A SISSY AND IT REALLY DOESN'T GET IN THE WAY. I DO NOT USE IT ON SOUND, WELL BALANCED, SPLIT FREE WORK, BUT I WEAR A FACE SHIELD. TRUST ME WHEN I SAY THAT THE FACE IS WELL SUPPLIED WITH BLOOD
Hello: I dont use the guard, it is out in my garage and has never been unwrapped. I did just find a real good use for the bracket for the guard that is on the back side of the headstock. I got a 3/4 inch rod, drilled a hole in it so the little spring pin in the bracket would lock the rod in place in the bracket. Then I made another bracket that would slide on the rod and attached my dust collector hood to that bracket with a bungee cord. It works real good, and with it, the dust collector hood can be turned and twisted anyway it needs to be to get in line with most of the dust that comes off my sander, regardless of what the ofjects shape is. I made the hood out of an aluminum shroud from an old heat lamp that years ago was used in my dads hog house to keep little pigs warm.
I too do not use the Powermatic lathe guard but do consider myself reasonably safety conscious in most of my activities within the workshop. I do not consider myself a highly experienced turner by any stretch of the imagination so I have occasionally placed a bit of excessive stress on a piece being turned to only have it release itself from the chuck or to break free from a glue block. No injuries at all and I never considered that the missing guard would have provided me with any improved protection.
What I have learned is to �read� the wood being turned a little better (extreme caution if you are trying to chuck punky or soft wood!!!) �listen� to the wood as you turn (the sudden arrival of a tick-tick-tick sound as you turn demands investigation). For me, education, experience and caution will add considerably to my safety in my home workshop.
Perhaps the included guard is more appropriate in a classroom situation where there are several lathes positioned in an open area.
Above is just one persons opinion and experience...be safe.
>I use mine every time I turn. I don't even notice it. I look past it while I'm turning. I wear a coat, hat and gloves when it is cold also. I don't care if those around me aren't wearing their coats or hats. If I'm cold I put more clothes on. I also wear my seat belt when I am in a car, driving or not. It might help. I don't want to find out the hard way I should have used it.
>I will try to get a couple of pictures taken this afternoon and put them up tonight if I can figure out how to resize them. I have never posted a picture here before. Jared
