Turning Mica Pen blanks
mark4583
>Anything Diffrent to Turn Mica Pens and how would you finish them?
Thanks
mark4583
Thanks
Re: Turning Mica Pen blanks
Scott Greaves in Blackfoot Idaho
>Hi Mark!
Probably the reason you don't have a lot of response on this question is we're not sure what you mean by a Mica pen blank. Do you mean an actual piece of mica, which is stone, or a plastic blank that looks like mica? If you mean the actual stone, I am not sure you can turn a pen from it. Most stone is too hard to turn on a wood lathe, alabaster being an exception. But I can't think of a stone that you could turn that wouldn't also be too brittle, or breakable, to make a usable pen from.
If, instead, you are talking of a plastic blank that looks like stone, then we can give you some good advice, or at least SOME advice! Let us know which it is, and we'll start jumping in!
Scott.
mark4583
>Its that Mica Swirl that Penn St has thats made from a Polyester resin, those and the Acrylic, Just woundering if there's anything I should know thats gona be diffrent from wood as far as turning and getting a finish. Im just guessing you wouild go with a fine finish and use a plastic polish of some sort?
Thanks
Phil Joines
>Keep your tool SHARP when turning plastic. If you get to agressive it will chip out prity bad so use light cuts. Actylic doesn't realy need a finish. I just sand it to 600 and use white metal polish.
