power sanding disc
power sanding disc
power sanding disc
Dennis Taylor
>After doing some hand sanding, think it is time to find a sanding disc, haven't used one, can someone make a recommendation for the tool and disc's...tks....hard on the hand, time to make a change...tks in advance...Dennis
Re: power sanding disc
Re: power sanding disc *LINK*
RevDoug
>I am using paper and mandrels from Industrial Abrasives. Takes some time to cut the yard x meter paper down to size, but the cost saving is worth the effort. Check the link below.
Turn 'em round,
Phil Axtell
>Hi Dennis,
Check out Vince's WoodNWonders at the link below. He is just starting to market a new system of discs and mandrels which looks very promising. I have some on order, but haven't received them yet.
Vince is a frequent visitor to this newsgroup.
Good luck,
Phil Axtell
Vinces WoodNWonders
Stuart Johnson
>I've just started using a Grex air powered RO sander (packards.com)along with hook and loop paper from Industrial Abrasives. The sand paper comes in 1 yard x 1 meter sheets and is easy to cut into 2" squares.
The RO sander is very comfortable to use but does keep my 26 gallon compressor running. The compressor and lathe are on the same circuit and will pop the breaker from time to time if I don't shut off the lathe. Other than it is time to run a new circuit I really like using the sander.
