Would you buy one of these?
Phil Joines
>I have been thinking about making an ornamental turning attachment for cutting spirals and flutes.
The design is based on metal lathes. The cutting device would be user supplied. A small router, Fordom, air tool or a Dremel for light cuts could be used with the proper holding device. It would mount on a carriage driven by a lead screw. The lead screw would be connected to an index wheel mounted outboard on the headstock spindle through change gears and link bar.
It would be able to cut spirals of any pitch and as many leads as you care to make and in either direction. It could, with the right cutter, make exterior threads. Because it uses gears rather than belts or cables it wouldn�t have �slippage�.
It would come with a full set of gears to make almost any degree of spiral.
It could cut flutes to any length, controlled by adjustable stops. The flutes can follow the contour of the piece.
The depth of cut is controlled by another adjustable stop. No need for a pattern.
The shape of the cuts would be limited only by the cutters available for the owners cutting device.
There wouldn�t be any extra �accessories� to buy except if you needed to change to a different cutting device.
I�d need to get around $750 for it. Do you think you�d buy one at that price?
Re: Would you buy one of these?
>That's very interesting and pirced right. As I remember the Nova ornamental attachment was just a little below this. unforturnately it was out of my reach at that time. I think there will be people who will buy this but I don't know how big the demand would be. It is less expensive than the legacy mill.
Phil Joines
>John,
There's never been enough demand for even the smaller companiea to manufacture them. That's why they all off the market and the prices seemed high. I think even 100 would be an excessive production run. I plan on making them to order with maybe 3 or 4 in stock. It's still very much in the planning stage, at least 6 months down the road. Nothing about it is patentable, it's all been around since the 1860's :>)
Re: Would you buy one of these? *LINK*
Gary Ratajczak
>Will it look like this?
http://www.bealltool.com/lathewiz.htm
JKJ in East TN
>How would it connect to the lathe spindle and bed? Would it fit all lathes, or just selected lathes, and if so, which?
No
Phil Joines
>The linkage on the Beal was partly by rubber O rings and hence had the posibility of slippage. Besides they aren't in production anymore.
Phil Joines
>For a full size lathe it would bolt to the bed. I would need to supply the clamping plate sized to the particular lathe. The attachment for the index plate would need to be lathe specific too.
Mini's are tougher, The owner would probably need to drill and tap mounting holes at each end.
