shop heating
shop heating
shop heating
>Darn I ran my kerosene heater all last night and my shop is only 41 this morning. it's 11 degrees outside at 6 am. Guess I need more insulation or a bigger heater. Of course Ihaven't checked the lottery numbers this morning. I only buy 1 ticket and the odds this time were probably 400,000,000 to 1 so my chances are slim but if I do win we're moving somewhere really warm.
Re: shop heating
Re: shop heating
georgetroy
>John if you can do it in your area. I suggest you go for a propane wall mounted heater with an large outside bottle maintained by a company who will fill them on a regular schedule. I have ventless propone heater in my shop(studio) which I have to turn down because it will get me too hot. Yes I'm well insulated.
Re: shop heating
Insulation is the key.
Bob Fawcett
>I built my house with ICFs (insulating concrete forms). Looks kinda like a foam block with a hollow inside. Stack them up like concrete blocks. Put rebar inside and pour full of concrete. You end up with poured conrete walls with 2-3" of foam insulation on each side, inside and out. Insulation value is claimed at almost R50. My heating and cooling bills bear this out.
Its also nearly hurricane proof and I need that on the Georgia coast. I nevered lived in very cold climates, but this should work just as well for cold as hot.
All this is probably irrelevant to your situation, but add some insulation. Its cheaper than fuel in the long run.
Re: shop heating
Re: shop heating
Joe Flemig
>John,
When I need to heat up my shop (garage) more, I turn off the fan. :-)
Joe Fleming - San Diego
Re: shop heating
Re: shop heating
Ed Moore
>John,
When we moved here almost 4 years ago my wife said that I should spend the money on a good heat pump rather than a new lathe. Since I felt that my lathes were more than adequate to meet my needs I listened to her. Since the day I turned the heat pump on I have never been uncomfortable in my shop. Yes, I did spend a little extra on insulation, and that was also smart. SWMBO earned some good points when she urged me to get the heat pump.
Ed
Re: shop heating
Re: shop heating
Bill Grumbine (Kutztown PA)
>John, I have a high tech radiant propane heater. It ain't cheap, but it keeps me warm even in zero degree weather. I hope to be able to convert the shop over to the outdoor furnace eventually, and then I will have a high tech propane radiant heater for sale. ;-)
Bill
Re: shop heating
Re: shop heating
>Ed I'm looking at a heat pump. I had planned to put one in when I move in but the electric bill for the house caught me off guard. I didn't figure I could afford 2 bills like that. As I get used to paying for this place I'll figure out how to do that but for now it's just not possible. With Kerosene or Propane, when I have money I can buy it. When I don't I won't. Using electric heat is kind of like having a credit card for heat. I'll use it and then regret it when the bill comes in at the end of the month.
Re: shop heating
Re: shop heating
>Joe Did I say I hate you. Well, Ok I hate you :) Well actually Jelous is a better word. The guy that came out to fix my heat pump just moved from San Diego. I'll bet he's hating that decision this morning.
Re: shop heating
Re: shop heating
Barry Turner
>I didn't go to my shop today, but I'm sure it would have been cold. Yesterday I was out there all afternoon and it was about 60 degrees with the help of a 220 volt milk house heater. Quite comfortable. My shop is 24' X 24' and has 12" of blown insulation in the attic and 3 1/2" in the stud walls.
Ray Sandusky and I were talking about the lottery today. If either of us had won, we were going to buy everybody a new Stubby. But some body in Nebraska got the winner we hear.
Re: shop heating
Re: shop heating
Skip Beardsley
>John... Insulation is the answer. It was 24 below here this morning and my shop was more that comfortable when I when out there about seven. I have an Empire through the wall propane heater which I love. Closed flame so don't have to worry about dust. Remember when you move to someplace warm year around you might have to contend with humidity and rusting tools.
Re: shop heating
Good tips, here's more
Dale Sherman - Pompey/Manlius, NY
>Good tips by everyone here. Radiant heat works great, heats you, not the space. Insulation is always a plus, but most folks forget airsealing. When you have a big delta-T (low outside temp, high inside temp), stack effect convective losses increase bigtime. Airseal with caulk and expanding foam everywhere you can find a leak. Make sure you're sealed well around doors and windows.
You'd be surprised how well it heats up once you've sealed it up. But be aware that unvented heaters will build up carbon monoxide, moisture, and other nasties when you have a tight shop. Buy one of those carbon monoxide alarms if you're using an unvented heater.
Dale
Re: shop heating
Re: shop heating
Guy
>Hello, Picked up a Dayton electric wall mount heater this year since the propane prices at my local place here in Kentucky have almost doubled this year. Must say the Dayton has kept the place nice and toasty. I turn it on about an hour or so before I go in. Cost about 20 cents an hour to run. Have fun, Guy
