ADVERTISE HERE - FREE TRIAL
Microwave drying question...
Blake Washburn
>Does microwave drying dry the blank completely? If so, can any body give me an estimated time to dry. I've got a couple of Hackleberry bowl blanks (already turned) I want to dry.
Blake Washburn
Re: Microwave drying question...
NEVER MIND :-)
Blake Washburn
>Blake I'll answer anyway. Obviously you can dry the blank as little or as much as you want in the microwave. I have lots of patience so I dry mine quite slowly. I start with 15 to 30 second bursts depending on warm the blank is when I pull it out. I don't like to get it really hot. I let it cool completely before the next cycle. After 8 or 10 cycles I increase the time. I don't rush it. I do other things during this drying period and whenever I think about it stick the bowl in and run another cycle. I have my scales there at the microwave and weight it regularly just before I put it in the oven. It usually takes me whole day but since I only run it when it's convenient it's not problem. I'm sure I could speed up the process but then I would have to monitor the process or sit there interupt some other process going on.
Bill Crommett
>At one of the natioal symposiums a demonstrator showed how he covered up some of the inside vent holes of the microwave oven to keep some of the moisture inside. This will prevent "case hardening" and allow the microwave oven to simulate a dry kiln by letting the moisture escape slowly and thus giving an even moisture content throughout the wood instead of drying out the outside faster than the inside and thus subjecting the workpiece to possible cracking. The results will be a faster drying process than Johns all-day proceedure which essentially does the same thing.
bob davis
>wrap piece in BIG towel in microwave,follow lucas procedure. remove toweled piece ,let dry in towel or place in paper bag to cool repeat procedure until no longer loses weight
