Hole in Bowl
Hole in Bowl
Hole in Bowl
Bob Herrman
>I was wondering if their was a site or tuturial on how best to fill holes in a blank using coffee grounds and Glue. Sounds simple, but are there some tricks or things to watch out for?
Thank you in advance for your responses.
Re: Hole in Bowl
Re: Hole in Bowl
Ken Ward
>Hi I am new to turning,but I have been doing woodwork for many years.I pretty much narrowed it down to custum made one of a kind jewelry boxes for about 8 or 10 years now and much of the wood I use is burl and figured woods.I resaw a great deal of my wood and love finding knotty woods,but sometime the knot gets lost or just isn't there.So what I have been doing for years is I mix up some epoxy then get some sawdust of about the same color of the wood and mix it together.I then put tape on one side of the hole and then put the mixture in the hole.I use a slow setting opoxy,then I may take a different color sawdust and create some swirl marks thru it to match the woodgrain.I have heard about the coffee ground fix,but have never tried it.I have been doing it this way for years and never had one come out or break on me.Feel free to drop me an email if you want to try this and have any questions.good luck.
Ken
Re: Hole in Bowl
Re: Hole in Bowl
Carole Valentine
>Hi Bob,
I always thought that a hole in a turning filled with epoxy or glue and "matching" sawdust looked exactly like what it was...a patch that is nearly always a poor excuse for a match. I leave a lot of holes and bark inclusions as they are because I like them. If I must fill for structural integrity, I usually use the 5 min epoxy/coffee ground deal if it's a compatible contrast. I grind the coffee very fine, mix it with an appropriate amount of epoxy, fill the hole or crack (building it up to slightly above the surface)let it dry then finish turn. Some people use key filings, but most filings are not brass anymore and look dull. Some use inlace or crushed stone. It's only limited by your imagination.
Re: Hole in Bowl
Re: Hole in Bowl
Norm Smith in Nova Scotia
>Hi Bob,
I sometimes leave voids if the look suits the piece, however I also use epoxy but I usually colour mine with pigment stain and than add brass, coppor or maybe puter powderor I might use various coloured stone. If the void is too large you could use some larger chunks of bark or whatever. If it is a hollow form with a void that you want to fill, put a balloon inside and blow it up, this will give you a wall to work with.
Norm
Re: Hole in Bowl
Re: Hole in Bowl
>I've found that I have to fill larger holes in stages,mixing the sawdust or whatever to change the color of that particular area of the patch. If I just mix plain sawdust it looks like I patched it with pressed wood. I try to simulate the look of a knot or already existing defect. I will sometimes make a patch and then grind away some of it with my dremel and then mix up another color. this way you can simulate that sort of Black to dark brown to tan that you get at the edge of a knot. It breaks up that big one color patch look.
I do agree with Carol. I don't patch much anymore unless it's small. Patches always look like patches unless you spend way too much time on them trying to blend them in.
Re: Hole in Bowl
Peter Charles Fagg (UK)
Re: Hole in Bowl
>Bob, Like many others I do not see the need to fill holes, it does tend to stand out as being a patch-up job. Personally I try to incorporate holes as much as possible, it seems to look much more natural.
Regards Peter.
Re: Hole in Bowl
Re: Hole in Bowl
>Lets try that again!
Re: Hole in Bowl
Re: Hole in Bowl
Jim King
>Peter: I�m with you. the more holes and cracks the better. Much more interesting . My 2 pence.
Re: Hole in Bowl
Re: Hole in Bowl
bob davis
>i mix my coffe grounds or matching dust with testors cement for wood models as it dries fast ...
Re: Hole in Bowl
Re: Hole in Bowl
Bob Herrman
>Wow! Again, woodworking takes me to another level. Guess it is better to leave the holes, unless small. I do have question for Peter, "How is it possible to continue to shape a bowl, as well as sand a bowl with that big of a hole in it?" Another Level!
Thank you for you replies.
Re: Hole in Bowl
Re: Hole in Bowl
>Sanding a bowl with a large hole is simplicity itself. Just keep your fingers out of the way!
Seriously, I make the bowl turn as fast as possible so that the free or non contact time is as little as possible. I still use my 2 inch sanding pads on an electric drill but take my time!
I use the same process for ALL my bowls with holes as in this example.
Regards Peter.
PS I will admit to a few disasters but that is why I have an open fire in my home!!!
