We value your privacy.
>I want to raise the bed of my lathe about 5-6" to bring it to elbow height. I can use two 6" square blocks or four 2"x6" (one under each pair of mounting holes). The question is though, what to use to make these 6" tall. I am thinking of laminating 2x4 stock (four layers). Is pine too soft? Using 8/4 hardwood seems a waste of good 8/4 stock. Other suggestions?
>George, I raised my old Grizzly 5 1/2 inches, by making a false bed, and putting it between the lathe bed and the legs. (The legs were already screwed to the floor, inside 5 gallon buckets filled with sand.) The false bed I made is from pine 2X6 laminated to 3/4 plywood. (Plywood is outside layer) Both ends and center crosspieces are made from pine 2X6 by themselves. Ply and pine is glued and screwed together, with holes bored to match bed and legs, just used longer grade 8 bolts. Sorry the pic isn't better. You could do the same by adding a 1/2 of ply to the bottom of the false bed to make it 6 inches instead of 5 1/2.
Just an alternate way of doing things. I guess it's my twisted mind.:o)
Anyway, I wouldn't waste hardwood, I think pine is fine.
>I raised my "mini-lathe" (a 16" Delta steel bed) up to elbow height using 2 layers of pine 2x6s under each end. The legs are an inverted T, so the bottom layer is two pieces with a couple inches gap in the midddle to give me four feet. Works with no problem.
When I got my Vic300, I had to raise me up to elbow height. I made a floor out of the 2x12 crating laying on some 1x4 runners which works great for both height and my feet.
