Have a question? Ask Woody!
Dang!
Dang!
Dang!
Rick Davenport
>Got the new 3520 set up, attached the new dust collector to the lathe and the bandsaw, added a riser to the bandsaw to tackle that wood I couldn't quite squeeze under the guides, hung the straw shades to protect the bench from flying shavings, generally rearranged everything to fit the new equipment, cut a piece of dry holly, put it between centers, turned the outside and sanded to a shiny 600 grit, flipped the piece around and mounted it on my talon chuck, got 1/3 of the way into hollowing the inside and BAM! the tenon collapsed and the piece bounced off the bandsaw base and onto the floor.
Dang!
The tenon was substantial, and I didn't catch the gouge but I was doing a deep cut. The holly was a bit soft, I'm thinking there was a weak spot that I didn't see in the tenon. (Gotta blame the wood, it couldn't be operator error)
Dang!
Redesign time.
Dang!
Re: Dang!
Re: Dang!
georgetroy
>Tough luck there Rick, I use thin super glue to reinforce the tenon
Keep it up. GT
Re: Dang!
Re: Dang!
richinva
>Rick,
Sorry for your troubles. I'm also playing with a bunch of holly....
Would you mind posting a pic of your D/C setup for your lathe?
Thanks.
Rich in VA
Re: Dang!
Re: Dang!
Bill Hale
>I do the same as GT on the tennon. Anytime I feel there may be a problem with the wood on the tennon I run a layer of thin super glue around the base of the tennon prior to taking it off the lathe. After it is cured I then reclean the tennon and then reverse to the chuck. You can do this on soft or punky wood. It also stabelizes a tennon that has a soft side.
Good turning and be safe
Bill in Casa Grande, AZ.
