Have a question? Ask Woody!
Which Woodburner
Which Woodburner
Which Woodburner
Doug
>I just want to learn to sign my work with a woodburner. What features should I be looking for in a system?
Doug
Re: Which Woodburner
Bill Grumbine (Kutztown PA)
>Hi Doug
For years I used a cheapie Woodburner from Walmart. It was slow, but it only cost me about $14.00 including the accessory tip package, which I had to buy to get the tip I wanted for writing. A couple of years ago I forked out about $100 for a Burnmaster Hawk. It writes a lot faster and easier, but if speed is not an issue for you, Walmart is just fine. When I am signing my work, I ALWAYS write what I want in pencil first, and then trace over it with the woodburner. It is a lot easier to erase or sand out a pencil line than a burnt line.
Bill
Thanks Bill
Doug
>Thanks so much for the advise. Time is not a big issue but easier is a big issue. My hand writing is a little shaky so anything to make it easier would be a plus.
Doug
Gil Jones
>I also purchased the Burnmaster (Eagle-With a 5 hand piece set), and it works great! Before the Burnmaster, I used a wood/leather burning kit from Wal Mart which, like Bill mentioned, works fine, but is slow due to being 45 watts, and cannot generate heat as fast as I could use it up writing.
Mike Rubes, Apex, NC
>Hi Doug,
I echo Bill's thoughts. I just bought a Burnmaster Hawk and having played with it just a little, really like it. It heats fast and is easy to write with. I bought the pen that takes different tips and they seem to be working fine. It's fun just to start drawing on scraps and see how it works. I got mine from Wood Carvers Supply. It was right at $90 plus the pens :)
Good luck,
Mike
Vicmarc.fan
>I am not saying the Canadian Razertip is any better than the others talked about here but I have had mine for 2 years and am very happy with it. Craft Supplies has it on special this month. I was afraid of the RCA connections but was assured I could return it if it didn't regain heat instantly and it does. Another fine burner is the Detail Master.
Ron
