Glass Bowl - Myrtle & Purpleheart
Chris Andrew
>This is one of my turned bowls incorporating kiln-formed glass. The primary wood is myrtlewood and the ring is purpleheart. Texturing was done with a Powercrafter. 8" diameter.
Chris Andrew
Re: Glass Bowl - Myrtle & Purpleheart
JKJ in East TN
>Stunning. Can you post a picture from a different angle?
Do you heat the glass to make it sump to fit a turned interior, perhaps over a casting?
BTW, I couldn't see your other picture.
Chris Andrew
>Sorry...I didn't take a side profile shot and probably won't have a chance to do that. It's a shallow bowl, approximately 3" high.
The glass is heated in a kiln to about 1275 degrees and allowed to slump into a bowl-shaped form. I then turn the wood bowl to fit the glass bowl.
Mike Rubes, Apex, NC
>Hi Chris,
That's absolutely beautiful. I love the colors and the look of that piece. What sort of form do you use to form the glass bowl. I've got a friend who is a glass artist and I would love to be able to conbine some of her talents into a bowl I turned. I am curious how you go about making the glass bowl. I assume your "form" is not wood! Maybe ceramic or something?
Thanks again for the pic. This one and the purpleheart one are just stunning.
Mike
Lots of ideas, not enough time to play in Apex, NC!!!
Chris Andrew
>Mike,
The slumping form is a simple round-bottom bowl shape. They can be purchased from places selling glass fusing supplies. You can also make them yourself using readily available mold mixes.
JKJ in East TN
>Thanks for posting this. I want to show it to my son's girlfriend who is a glassblower, and to my potter friend. The potter has a small electric test kiln that would be perfect for this, and he's a woodturner as well.
Stuart Johnson
>Chris, What is the form for slumping made from and how do you make it? You certainly have an eye for picking the exact color match. Great job of combining two mediums.
I need to keep reading befor asking.
Stuart Johnson
