Drying hollow forms
Drying hollow forms
Drying hollow forms
Devon Palmer
>Heyas all,
I'm getting ready to make a little urn for a friends departed kitty. I'm going to try and use green wood to rough out the form, but, it'll move when it dries and I'd like to be return it so that I can fit a lid to it.
Can I use the same rules as bowl turning and leave everything at 10% thickness, let it dry (will actually try and slowly microwave) and then when its down to EMC, return/rehollow it? I would think that it would be prone to flexing given the size of the base, etc.
Any advice would be greatly appreciated.
Re: Drying hollow forms
Wally Dickerman in Arizona
>Depends. The 10 percent rule is a bit extreme in most cases. If you're turning end-grain, that is, with the grain running from top to bottom, warping will give you very little problem. Some woods will warp a lot more than others. Give us a little information on the wood you're planning to use, and what size it is. Often, rough turning a second time, after the wood has moved will cut the drying time quite a bit.
Wally
JamieDonaldson
>Much depends on how wet the wood is when turned. I turn my hollow forms to completion, but the wood is not dripping or slinging wet when started. Then seasoning is completed in a Polish kiln(brown paper bag) right in the shop for a week or weeks, whatever is needed, but the wood is practically dry by the time turning and sanding are completed.
kkamm
>Has anybody used alcohol method with hollow forms? If so, how did it work out?
Polish Kiln ! ! !
Barry Turner
>So, that's what I have been using! I just didn't know what to call it. In my ignorance, I have been calling it a brown paper bag.
Les Robison
>I use the alcohol drying method on hollow forms most of the time when turning green. I have had pretty good luck. I have used the 10% rule and find it makes little difference (most of the time) vs. turning to completion then soaking. I have used this on olive, walnut, apricot, buckeye, and african sumac.
