Platter Blanks
Doug Reynolds in Seattle
>What is a good starting thickness for green wood platter blanks that will be about ten inches in diameter (limited by a Jet mini)?
Platter Blanks
Re: Platter Blanks
Gary Evans Tallassee, TN
>Hi Doug,
It all depends on how thick you want the finished platter to be. If you use a glue block, you can make platters from 4/4 stock. If you use 8/4, you have room to put your tenon on the workpiece, but you have to turn away a lot more wood.
Gary
Re: Platter Blanks
>Depends on grain direction also. If it's flat sawn you will get more cupping as it drys but at 10" probably not more than 1/4 to 3/8". I would go with Gary's 4/4 to 8/8. That's pretty safe unless you like big tenons for holding.
