A55 Smoothing Plane
Storing wood
Storing wood
Storing wood
Steve
>Hello all,
I recently got lucky enough to save a maple tree from the firewood pile. It is already cut into aprox. 16" long logs. Would it be best to cut it into blanks, seal and store. Or, seal the ends of the logs and keep them outside until I'm ready to use them?
P.S. these logs are streaked with great Ambrosia marks and some curl.
The same person I got these from has some large diameter pecan logs and some cherry also.
Any help on storage would be greatly appreciated.
Steve
Re: Storing wood
Re: Storing wood
Gary Evans Tallassee, TN
>Hi Steve,
I'd be willing to help by storing the Ambrosia for you, particularly if you promise not to count the pieces ahead of time. 8^]
Seriously, either method that you mention will work well for you. If you want to store the wood for a long time, say 2 or 3 years, or longer, then I'd recommend processing into blanks as soon as possible. AnchorSeal the ends and any grain that isn't perfectly straight and store somewhere with relatively high RH. After the wood gets a year or so on it, you can safely put it somewhere a little drier.
On the other hand, I've had good luck storing wood outside in short log form for up to a year with very little degrade. You might even pick up a little extra spalting in that time.
Gary
Re: Storing wood
Re: Storing wood
Ed Karch
>If you want to keep your ambrosia white and avoid blue stain I would recommend processing as soon as you can and store inside.
Re: Storing wood
Re: Storing wood
>You are exactly right, Ed. It didn't register that he was talking about white wood. I guess that shows how long it's been since I've had any Ambrosia Maple! 8^]
Rapid drying is the priority with white wood.
Gary
