We value your privacy.
>After reducing the belt tension and backing off the toothed locknut on my Stubby 500, I roughed out a bowl today. To make a long story short, it worked. There was no real heat in the headstock. It was less than I would have expected in any lathe. Needless to say, I was quite pleased. The reduced belt tension was probably the big factor in the improvement. Of course, when I was agressive it slowed down. Before, it would not have slowed. I'll take that in exchange for no heat problems.
Thanks to each who provided help in my earlier thread.
Not familliar with your machine design, but the pre-load was probably most of the issue. With the belt off, the spindle should turn freely with no binding or drag. Do this cold, and warm. Bearings and shafts do expand with heat and what may feel good at room temp, may start binding once warm. Ideally the thrust adjustment you speak of works around one bearing on one end of the shaft, allowing the other end to float (due to expansion & contraction) in the other bearing, but that is not always the case.
Belts need to be tight to provide adequate horse power transmission. Overtightening may be a sign that, in respect to v-belts, that the belt is worn or the pulleys are worn. Worn v-belts drop to the bottom of the v-groove. V-belts must only contact the sides of the pulley. Once they touch the bottom of the v-groove, they lose their ability to transmit the horse power.
>..came on the Stubby 500 in those days? I don't recall ever seeing one in person, but I love my Studly 750 and nothing I have ever attempted slowed it down!!
I think the motor says 1.26 kW, which may be about 1 2/3 HP. The specs on the Stubby website says 2 HP. They still produce the 500, but they don't market it in the US now.
When I had the belt tighter I always had plenty of power, so I attribute any slow-down as being a result of the looser belt.
