Box elder bowl
Box elder bowl
Box elder bowl
Sam Dean
>OK, this is the last one for now. Box elder bowl with some of the nicest red coloration I've ever seen. It's about 12" in diameter and 5" tall. Finish is watco danish oil, then buffed on the beal. Thickness is around 5/8" on the walls with a much thicker rim. Comments and critiques are encouraged and appreciated.
Thanks,
Sam
Re: Box elder bowl
Re: Box elder bowl
>I love the coloration. It is QUITE colorful. The inside curve is smooth and continuous. Is it the photography or does the outside "swell" a bit just underneath the rim?
Re: Box elder bowl
Re: BTW - have you used the bits yet?
Re: Box elder bowl
Sam Dean
>Hi JL,
Good eye! It does indeed swell below the rim. The diameter is the same around the rim as it is 1/3 from the bottom.
The bits are great, thanks again! I've been using them for all sorts of things. They're much nicer to use than a jacobs chuck and a regular drill bit.
Thanks,
Sam
