We value your privacy.
Here's another one in ambrosia maple. About 11.5" in diameter and 3" tall. Sanded to 800, a few coats of danish oil and buffed on the beal. I think the next one will be about twice as tall with slightly longer "legs". Comments and critiques are encouraged and appreciated.
>Very Nice. Love the leg feature. Could you post a pic or two of the underside and legs. How about a brief discription on the technique or process for turning the legs.
I use music wire, from the hardware store, wrapped around two dowels on the ends and just hold it against the spinning piece to burn them in. Sometimes I get caried away and put waaayy too many lines in because it's so fast and easy! You can use just about any metal wire - I've even used 10 gauge copper wire (like you use wiring a house) for some really bold, thick lines.
Thank you! I'll try to take some more pics, but it might be next week. The bottom just continues to curve around, no detail or anything, just smooth. The bottom has about 3/8" of air under it when it's setting on a table. BTW - I made a longworth chuck to finish the bottom of the piece. It was actually quite simple to make and holds work like this perfectly.
Thank you! I can't take any pics right now, maybe next week. In a nutshell, the legs start out as a rim around the bottom of the bowl, that stick out further than the bottom. Think of it as a bowl attached to the back side of a bowl. The rest of the work is done off the lathe. I lay out the spacing for the legs with dividers, and make a cardboard template for the final shape so they all look alike (well, only if you don't look too close!!). After marking the outlines from the template, I use a dremel tool with a carbide burr to carve out everything that shouldn't be there. The shape is refined with a 1/2" drum sander and finish sanded by hand. I hope that helps a little!
I'm sure others here have done similar designs and might be able to add a little. I'm pretty sure I was inspired by something that was posted here about a year ago, but I just can't remember who or what.
>Hi Sam, thanks for posting this piece. This appears to be very well executed. I think the proportion of height to width is very good, and the overall form flows very well.
I really like the idea of supporting the form with legs, as this opens up a whole realm of design possiblities. Because of the legs, the piece can be viewed a a furniture piece, or even an architectural piece. The tapered legs are a feature common in furniture, and help give a feeling of lightness.
I suggest that you consider lightening the legs even further, down to perhaps 1/4" or so where they contact the surface they sit upon, and possibly even eliminating two of them. As it is, the legs overwhelm the rest of the piece, and seem to anchor the form to the table. Some people refer to the appearance of a piece as either masculine of feminine.....one suggests strong, muscular lines, while the other suggests graceful, delicate lines. I believe your legs give the piece a blocky, masculine appearance.
I'm unsure about the burnt lines, as you have many design elements in the piece. The legs, the form, and the strong grain pattern are enough to make the piece stand out. It would be worth trying a similar piece without the lines, and a continuous exterior flow, right to the rim.
Lots of good stuff here, I would be interested in your thoughts...Keith
