Re: Bias turned
RevDoug
>Dave, easier than that. Started with a cube. Two of the opposite corners were cut off to give me a flat spot for the two centers to take hold of the blank. Tailstock end will become the bottom, headstock the top of the bowl. Turn the bottom half down to the point you want to stop, pretty close to what you want your final shape to be. Turn a tenon for your chuck as well. Reverse the blank, mounting the tenon in your chuck and bring up the tailstock (for safty). Turn the entire outside to your finished shape and begin the hollowing. Do as much of the hollowing as you can with the tailstock in place. Once you've gone as far as you can, remove the tailstock and finish the hollowing of the piece as normal.
Safty Note: You will want to be very careful with the "tips" that emerge. They will bite you.
Finish the turning, sand and finish. You're done. Can also be done with a cylinder which leaves a large lip out to one side. Good luck and have fun.
Turn 'em round,
