Cutting Crotchwood On The Lathe
George Van in WI
>Since the subject for chat Wednesday night is a platter, I thought I would mention this method of cutting a crotch. I am not that good at centering the three piths when cutting crotches with a chainsaw and waste too much feather at times. I had a 16� walnut crotch that was given to me by a friend and wanted to get the most out of it. Instead of chain sawing the pith I cleaned up the crotch section with the chainsaw saving one slab for a 12� bowl. I then put the crotch log section on the lathe between centers with the piths spinning perpendicular to the bed. I adjusted the log on centers till it was balanced as well as possible and started to true the crotch. When I was able to get a good view of the three pith centers I started repositioning the log between centers till all three piths were aligned on the same pencil mark. I then turned the log till smooth at which time I used my McNaughton straight knife (parting blade) to part the log through the piths to within an inch or so of center. I finished parting with a handsaw. I then remounted the two blanks between centers and roughed ads usual. These are the best results I have had getting two blanks out of a single crotch, the Anchorseal clouds the figure. Hope this helps someone who needs an alternative method. George
14� Walnut Platter Blank
15� Walnut platter Blank
Re: Cutting Crotchwood On The Lathe
Allen Neighbors
>George, I wish I had known this a couple of days ago. I,ve always had trouble with this for the entire year and a half that I've been turning. Thanks for the heads up.
Allen
Phil Powell
>Wow! Goerge that is some gorgeous wood! Looks to me like you
cut it just right. Beautiful platter stock. Now that's a great friend.
Phil
GaryG in MD
>George,
Excellent idea! Thanks for the tip.
Gary
George Van in WI
>You betcha Phil, WCer Rick in Colgate!
Dave Belser in NH
>Yes lining up the piths in a crotch can be a pain. What I struggle with is the trade offs of orienting the pith towards the rim or the base of the platter/bowl. If it's the rim a lot of figure gets cut out when I hollow, if it's the base - the bowl or platter gets a lot smaller because of tree diameter.
Anyone else struggle with this and what do you do? I've seen a few end grain crotch vessels but have yet to try one.
George Van in WI
>For me Dave, with my limited experience, it depends on the crotch. In this case the figure goes from top to bottom. If it were a smaller crotch I would do as Dave Winters taught me and go for one bowl/platter between the crotches. I tend toward platters or the figure in the bottom of the bowl if a deeper bowl.
Ric Taylor
Ric Taylor
>I usually go for the best figure, which means putting the pith side down on the bottom. To me, the size of the piece is secondary to having some beautiful flame figure.
Ric
