Preparing Green wood for Pen Blanks
mark4583
>Whats the best way to prepare green wood for pen blanks?
should I cut to a larger square size, coat with a sealer and set to dry?
Whats the best process for this?
Thanks
Re: Preparing Green wood for Pen Blanks
Gary Evans Tallassee, TN
>Hi Mark,
The pro pen makers can correct me here, but I think you'll end up with less waste if you slice your wood into planks of the necessary thickness, 5/8" or 3/4" x whatever width. Coat the ends with sealer and put up to dry on stickers just like lumber. Saw into squares of the correct length after the planks are dry.
Gary
RevDoug
>I'll probably get chastized for this, but I've never had trouble turning green blanks. Species of wood does make a difference. Madrone, apple, most nut woods are know to move a lot. Those big movers I would cut into 3/4" or 7/8" and to length and either boil them or try the DNA process. Either way I believe you will come out with usable pen blanks.
Turn 'em round,
