We value your privacy.
>I go between centers, make design, true up, turn foot, reverse on chuck, true up, turn inside. Bowl is sealed on outside before I reverse and pits/cracks sealed with super glue. After inside is turned, they are put on button jaws with tailstock brought up. I will tape around the edges if I think they might fly off. The bottom is brought down to the waste point and then is taken off with a carving chisel. I will use a 1� hook & loop disc to sand bottoms. Sanding inside and out is done with an inertia sander, I have both a 3� and 2�. Finish is Deft Clear Wood Lacquer, then Tung Oil type finish of choice. Size ranges from 8-6� wide to 3-6� high all approx. �� thick. GT
>For me I think it is somewhat more difficult than Walnut & Cherry. Better than Oak, but I'm turning green. It can be very hard if full dry. I think this is Honey Locust no thorns on this tree. Not positive of species here. It does have a lot of character in the pit area. Sapwood can run white to yellow with some gray areas in it. I don't think I want anything over 12", this wood is heavy. If you have a chance to turn, give it a whirl and see what happens. GT
>Nice job, Geroge. Honey Locust (unless it's a thornless hybrid)does have thorns on the branches. I think at one time the thorns were used as nails, at least that's what my Dad used to tell me.
>Thanks. I have a couple of tons of black locust logs on the ground that I planned to try to saw into fence posts, and three large standing trees that need to come down this year (one is way too close to the house and is dropping branches.) I wondered if it was worth cutting some bowl blanks from the butts or root ball. I haven't tried turning any and probably won't have time until at least next winter. Anyone who wants some is more than welcome to it.
Black locust has small thorns on the twigs (usually about 1/2" long or so and always in pairs) but nothing like the long branching thorns that grow out of the trunk of wild honey or water locust. My books mention thornless cultivated varieties of honey locust but I haven't seen any myself. If the tree came from around a house it may well be a thornless honey locust. If you found the fruit or leaves you could also tell - the honey locust pods are much longer than the black locust, and the black locust leaflets are rounder instead of narrow. (Not much honey locust around here but black locust grows like weeds, and very fast weeds at that.)
