A55 Smoothing Plane
John Lucas: Re: Small Light tent
Allen Neighbors
>I built a light tent from the instructions sent in yesterday. I think I need a couple of more lights. Right now, I just have two desk lamps with 40w bulbs. I had to brighten both pics. What will do the trick? Three? Four? Higher wattage?
I set my camera for incandescent lighting. The color is pretty true to actual... This is my first lidded box made from a single piece of wood. It's some Madrone I received from Bob D, in Oregon.
Followed Cindy Drozda's instructions. I have no idea where that design came from... if you can call it that.
Re: John Lucas: Re: Small Light tent
Re: Lid Removed
Allen Neighbors
>The box is 5" tall, including finial. Inside follows contour of outside. About 1/8" thick walls, except bottom's about 3/16".
>Allen I believe you have 2 problems. It looks like your light tent material is either too thin or you are shining the lights directly on the subject without going through the tent fabric. Consequently you have the 4 little hot spots on both sides of the piece. These very bright highlights will fool you camera meter and make it underexpose the piece.
You camera meter is set up to recognize an average scence which is gray. If you have that much white background the camera will try to make it gray and will also underexpose the piece.
The solution (I hope) is to start with one of the lights up higher shining through the top and one side panel. Then shine the other one though the other side. 40 watts is a little low but if you camera is on a tripod should just mean that you need a much longer exposure. I use 300 watt quartz halogen lamps. Your lights are also a little orange to the camera compared to the quartz lights which are very close to the tungsten setting on your camera.
The final thing to try is to set your camera to puposely overexpose slightly, if you have that option. Many cameras have an over/under exposure mode or dial. You can set this to +1/2 or +1 if it has it. If not, and you can set your camera to manual mode, then adjust it so that it is overexposing a little.
Hope this helps. Feel free to e-mail me. If I can see a photo of your set up I can probably help better.
Allen Neighbors
>John, thanks for your response. I feel pretty stupid. When I owned a photo studio, I never had a need for a light tent, and now that I'm out of the business, and have no decent equipment, I need one... and to top it off, I guess I've been away from it so long, I can't remember anything.
This is a shot (using flash, and I can't even get it to come out right) of my little tent, and the two desklamps. Let 'er rip.
Thanks again, for all your time and professional knowledge.
Allen
>Allen I see this a lot. Your box is too wide. You can't get the lights far enough out front. You may be able to simply put the turning back further. If you have another stand of some sort simply bring the cloth around front toward the camera more. Then put the light behind that. You might also move the lights further from the panel. When the lights are really close they make a spot, which you see reflected in the piece. By moving the lights further away you illuminate the panel more evenly. This will help get rid of the hot spots from the light.
I dubb thee,Sir John...
Allen Neighbors
>Thank you, Sir, for the help. I can see that now. I will make it deeper, and with the additional lights and more powerful bulbs, it will work much better. Thanks again, John.. It's wonderful the way all of you folks on this forum help everybody else.
Allen
Keith Tompkins
Re: I dubb thee,Sir John...
Keith Tompkins
>Allen, if it helps, the shot you posted was better than anything I've done....ever. I gotta make one of these tents!
>Building a light tent like I use or building an opaque light booth like Jamie teaches is only the first part of learning to shoot work. Unfortuntely because of all the variety in shape and reflectivity of the subjects you must be willing to experiment with everything. Anything that changes the way the light hits the tent will affect the final results so it's more of a matter of learning to see the problems.
The most common probems are the lights being too close and too even. Back the lights off so they light the panels more evenly and make one light dimmer. An easy way to make on light dimmer is to simply aim it less directly at the piece. If you have white ceiling try aiming it at the ceiling. To illustrate this concept at one of my workshops I used only one light. I aimed it at the ceiling. This made a more even light but the piece was dark at the bottom so I added a mirror to bounce some of the light back into the piece.
Allen Neighbors
>Hearing Keith Tomkins say that means something to me. Thanks, Keith.
I did add three inches to the depth, and turned it around. Then I rigged a hanger for my roll of background paper at the top rear, where I just grab the edge of the paper and pull it over the top rear rail, and let it flow down to the front edge, making it seamless. I added a white handkerchief over each light, further diffusing the light, and then changed some settings on my camera. I think it did some good. I'm still going to add some more lights.
Thanks, you two!
Allen
Re: better photo size
Allen Neighbors
