A55 Smoothing Plane
Denatured Alcohol and West System Epoxy
Barbara Gill, Remlik VA
>Has anyone used West System epoxy on wood that has been soaked in denatured alcohol? I know the alcohol is supposed to be gone by the time the item is re-turned however each time I do this I can smell alcohol.
Re: Denatured Alcohol and West System Epoxy
Richard Allen
Richard Allen
>The three brands of Epoxy I have used all call for alcohol to cleanup. I would expect epoxy and alcohol to be counter indicated.
>BArb Can you put a glop on the outside of the wood and let it dry and see if you can peel it off. That would probably tell you if it is reacting with the alcohol.
>Richard, that was my thinking too.
John, I haven't soaked any of these burl bowls because I will want to do some filling with West. I didn't want to risk ending up with a mess of epoxy that wouldn't cure. I boiled the three I roughed out today. The two yesterday were bagged and put on a shelf; one was too big to boil.
I might soak the next one and then try the epoxy down the road.
Don Pencil
Don Pencil
>Barbara;
Those two are often mixed together as a dry rot cure. West Systems is mixed with either denatured alcohol or acetone for this purpose.
Once wood is socked in alcohol it takes a long time to get all of the alcohol out. It works kinda like water in the wood. Thicker the wood the longer it will take to get it completely out. These are mixed with West Systems because they both mix with water on a molecular level. When the acetone or alcohol evaporates it takes the water with it and leaves the epoxy behind to cure and hold everything together.
these combinations are used on boats when dry rot is present and cannot be cut out and replaced with new wood.
Be well,
Don
>Thanks Don, that is some good information.
