THE WOODRAT IS BACK!
PM outboard spindle
PM outboard spindle
PM outboard spindle
Vince
>Anyone know the thread size for the "outboard" spindle of a PM 3520a? Had intended to take handwheel off and install a oneway rotary adaptor for a vacuum chuck. I had never noticed, but now that I look, the threading is clearly different in & out-board and I cannot find any indciation in manual or on web of the outboard spindle thread size. Any help/thoughts appreciated.
Re: PM outboard spindle
Chris K in MD
>Its not a thread its a straight shaft but I would suggest that you dont use the oneway rotary you cant use MT in the madrel. The problem is there is no way to knock them out with the rotary adaptor installed and it takes a while to get it off. I use the EZ vac adaptor on my 3520A and like it a lot.
Chris
>I had my handwheel bored to accept the bearing assembly that I had with my Nova 3000. It's pretty simple to make if you do this. The nice thing about this system is you simply pull the bearing out when you need to use the Knockout bar. I did have the EZ vac system and it works really great but I like this better.
Vince
>Thanks for the info. The Manual's exploded view shows the inner diameter of the handwheel as threaded, so i had just figured the spindle was threaded the whole way out matching the thread used for the bearing lock nut/washer (or was at least threaded--but looking at the diagram again...the spindle does appear to be two stepped at the end). ah well. thanks for the info.
Chris K in MD
>John,
Do you have a picture?
