Wood for Segment bowls?
mark4583
>Been wanting to try some Segment Bowl's and seems like wood suppliers in this area doesnt offer much to choose from.
Only one's I can find here are Lowe's and Menards which doesnt have much of a variety plus its a little pricey.
Not looking for anything excotic, just some variety of dry wood.
I live just outside of Springfield Illinois, anyone know of any in the general area? I keep comming up empty on any web search's.
Thanks
Re: Wood for Segment bowls?
Re: Did you try Woodfinder?
>Also, try cabinet shops for cut-offs. If you want exotics, you'll have to order.
gary s clarke
>I have had good luck with the following: http://woodworkerssource.net/Company_Info/company_info.html
>Do you have a Lumber Liquidators in your area? The sell wood flooring. I have not tried it personally, but have been told that you can strike up an acquaintance with some one there and get scraps. I am actually thinking of one of their facilities where they bring in the wood form South America or where ever and process the wood into flooring, but they may also have scraps where the just sell it. I know they have purple heart and Brazilian Cherry (jatoba?), ipe and others.
Brian Hahn in SW Wisconsin
>I've had good success with woods like black walnut, cherry and maple - common hardwoods that should be readily available in your area. But you might have to go to a real lumber yard to find them.
Local woodworking stores are another good source for smaller quantities of lumber. You might not find them on the Internet but the "yellow pages" should yield at least a few leads.
As someone else already mentioned, try local cabinet shops. (Check the phone book.)
Stuart Johnson
>You can make some nice segmented pieces using plywood. If you have to deal with voids fill them with colored epoxy for a good effect.
Terry Quiram, Roanoke Illinois
>Mark
Which direction from Springfield do you live? There is Woodworkers shop in Pekin on the Manito blacktop. They have a very large selection of domestic and exotic hardwoods. It would be approx a 2 hour trip from Springfield. http://www.woodworkersshop.com/
Terry
chris rolke
>you could always try a 2x4
anything will work
Fog Tanner
>I made a number of pieces from Blue Pine and they came out nice. I made some boxes and was able to get seven of them from a 2x4 log. You can go through the log pile at your local Lowes and find one with interesting grain and get your feet wet in segmented for a pretty small cash outlay. I have a number of short 2x4 logs which I am turning into a bowl. There is also a millworks in our area which has short (1ft) cutoffs that they put in a pile for the local residents, another source for real cheap wood - you might have something like that in your area..
Pine - the other white wood...
