drilling dear antler
Blake Washburn
>I brought this question up a while ago. How would I drill a chunk of deer antler!
Blake Washburn
Re: drilling dear antler
Jake Niedling
>The antlers that I have drilled was no different than a hard wood. So just use your standard drills.
RevDoug
>And take your time. Remember that the smell is pretty bad, so be prepared.
>Blake I don't have any trouble drilling it as long as I go slow but I have trouble finding the center if the antler is not very large. I cut off a section longer than I need and then mount it between centers. Readjust the centers until it looks like the fattest part is in the middle. Then turn just a little to see. You will be able to tell pretty rapidly whether you've got it center and if it will be thick enough for a pen. Readjust as necessary.
When I get it running as true as I want I turn a short tenon on one end. This will go in my drill press vice. Then it's pretty easy to drill it on that center.
This method also works well if you purposely want to put it offcenter to leave some of the natural edge showing.
eaglesc
>I'm going to take as hot at possibly part of your question relates to the fact that most antlers aren't square.
There are 2 ways to deal with this.
sand one side flat and then cut the other side so you can use that 90 degree side in a pen vice.
The otehr wy is to chuck it between centers turn round and then using the appropriate chuck drill on the lathe.
The latter method allows you to get a pen out of a picece that is "scalloped"
There are other methods I use with jigs on my tablesaw for "squaring"
Eventually you will come up with a method that you are comfortable with
IT WILL STINK!!!
Ken Oakley-Sunny St. Cloud, Fla.
>Like when you singe your hair
