REAL MILK PAINT
Help -T Daniel -- Milwaukee Drill Photos?
George Van in WI
>I procrastinated on the bearing replacement as I thought my drill was noisy when I bought it and it did not seem to be getting any noisier. Well it got noisier in an instant yesterday and I may have caused more damage than a little prevention time could have avoided. Before I took it apart I looked for a review with the photos you took of the repair you made just recently and I am unable to find them. Do you know if they are available? Am I just looking in the wrong places? I have the wiring diagram that Darryl Hansen Thankfully mentioned and the previous posts on the repair subject. Thanks for any help, George
Re: Help -T Daniel -- Milwaukee Drill Photos?
Mac
>George, If I remember right,Terry said he was going out of state to deliver a lathe, he should be back soon,so if he doesnt answer soon, maybe someone else will help you get the info you want....
Darryl Hansen
>George I may be able to help a bit. The major problem you will have when you reassemble the unit is that the wires on the side must be routed under the switch unit on the way to the armature. The other tricky thing is the trigger. Let me know if there is any thing specifically I can help you with. I have had both modles the old and the new apart and they both gave me a bit of challenge but they do go back. :>))
George Van in WI
>Thanks Mac!
George Van in WI
>Thanks Darryl, I am going to order a bearing. I was told by email that the drill has a 5-year warranty, mine is one year old. I am going to check with the repair center tomorrow morning to see if it is indeed still under warranty. I do think there is more than bearing damage. If they do repair it I will install a sealed bearing as soon as it is returned. I may lean on your knowledge when/if the unit is returned.
Thanks for the help, George
Phil Powell
>George,
I remember when the thread talking about the bearings was up. I read it
and wondered why new bearings was a topic. I now know. My Mil. close
drill sounds like it swallowed a rattle. If you remember the Co. with the
cheap bearings let me know. Harbour Freight has a knock off on sale right
now for 20 or 30 bucks. Maybe that's the way to go........disposable!
Phil
Bill Neddow
>George, if you take it in for a warranty repair, don't volunteer the information that you have been sanding with it. I did, and it instantly voided the warranty. The drill was 10 months old. I got it repaired anyway ($80) and it lasted three months. Threw it away and got a knock-off, for $39 which is still going strong after four months. Maybe I have been lucky with the knock-off, but it is proving much cheaper than the Milwaukee.
If you do the repair yourself, make sure you get a sealed bearing, not a shielded one, which is the problem. Dust seems to get past the shield.
Enco bearings and a photo *LINK*
Ed Kelle
>Enco part # 510-1961
.25 x .625 x .196 Double sealed radial bearing
Here is my photo from when I installed a new rear bearing
Enco bearing
Re: Help -T Daniel -- Milwaukee Drill Photos? *LINK*
George Van in WI
>Hi Phil, a while ago Ed Moore provided the part number FP510-1961. The link is below. They are double sealed and on sale for $2.39.
Enco Bearing
George Van in WI
>I will be careful what I say Bill! Maybe you found out the best way to go with the knock off. I have not used mine as much as you as I have been roughing too much, I thought that it would last longer. At $2.39 I am going to get a few bearing to avoid this in the future.
Re: Enco bearings and a photo
George Van in WI
>Great photo Ed, thank you! I am assuming the red and blue are the bearing and the green outline is a pivot point for the switch.
Ed Kelle
>Red and blue are motor brushes, and the blue has a wire that goes in under the motor. Green is the pivot. Rear bearing is behind the fan, you grind the old one off vary carefully.
Prop up the trigger during reassembly and so will not fall out.
George Van in WI
>Thanks Ed!
Bill Crommett
>Has anyone had any experience with the Chinees knock-off of the Sioux angle drill ?
I bought one from Big Lots Friday and I wonder what to expect. I figured for $24.99 it could almost be disposable.
I'm back
TDaniel
>George, I just got back from delivering a VB36 to Mississippi. The origianl bearing in the Milwaukee drill is made in China and is not a sealed bearing. Enco has a sealed bearing that is also made in China and it was on sale a month or so ago for less than $3 each. I buy double sealed bearings that are made in Japan and seem to be of higher quality but they are $10 each. The one that gives the most trouble is the one just behind the armature cooling fan; it seems that the dust is blown into this bearing. I have several photos that I can send you if needed. The drills that were on ebay recently were the old style and those have a for/rev switch that is no longer available. A guy in our club just took his old style to a Milwaukee service center and got it back in a box (unassembled).
TD
Re: I'm back
George Van in WI
>Thanks Terry, wish that VB36 were in Wisconsin.
I hope my drill doesn�t come back unassembled in a box. That is poor that a drill one year old does not have a rev switch available. It does not say much for Milwaukee Tool. They used to be a leader! If it is returned repaired I will replace the bearing before I use it. I do not want to go through this again. I will pick up a knock off while in Phoenix this weekend for the Dessert Roundup, that way I will have a spare and if I am as lucky as Bill it will do a good job.
not Milwaukee
TDaniel
>The close quarter drill that Milwaukee sells is made by Siouz. Apparently, the switch that was being used was discontinued by the switch manufacturer and Sioux had to redesign the case for another swich. Those selling these drills had no idea that the switch was no longer available. The switch can be bypassed making the drill run in one direction only. Perhaps someone will come up with another switch that will work in the space.
Re: not Milwaukee
George Van in WI
>Thanks Terry, The switch problem is now understandable. Are you aware of a serial number (before/after) switch change? If not I will check to see if I can find out.
If it is one the back it is the old one....
TDaniel
>the new one is on the top near the rear.
Re: If it is one the back it is the old one....
George Van in WI
>Thanks Terry, looks like I lucked out, mine is in the top-rear!
