ADVERTISE HERE - FREE TRIAL
Pen Turning startup (just to try) requirements
wilzirkle
>I�ve been searching around but not found a good answer yet, maybe someone here can help. I don�t see myself becoming addicted to pen turning (famous last words I know) but I can�t help wanting to try it. It seems to me that there is a cost to just trying it, either I have to pay for a class or buy the startup materials. I already have a lathe on which I attempt to turn a few bowls on every year, and I am ok on the gouges, but I don�t have drill press or any of the other pen tools. I know I would have to get a mandrel, blanks and pen innards but from reading about the startup kits on the various store sites I would need to get more than that, and even then a drill press seems like a big piece of the puzzle.
So what I am asking is with just a lathe, the gouges, glue, and some finish; what is the minimum I need to purchase to get a final pen.
Wil
Re: Pen Turning startup (just to try) requirements
Ron in Drums PA
>Here is the best info around
http://woodturnerruss.com/Pen10.html
HEY JIM, it's time to share your article on making pens!!
Jake Niedling
>Well you are going to need a pen mandrel to fit your lathe. Buy a slimline Pen kit and the bushing for the mandrel for the slimline kit. Buy some pen blanks that are all ready drill to the correct size for your kit. I would suggest starting with the slim line kit which requires a 7mm dia hole. I know you can buy the blanks with this hole size. Once you turn the wood barrels, use a quick hand clamp to press the parts together. Good luck.
Thanks Ron and Jake
wilzirkle
I Guess Now Is a Good Time Russ/Ron? *LINK*
Jim Shaver - Oakville, Ontario
>Thanks Ron,
Russ has a great tutorial in the link provided by Ron, so not to steal Russ's good work I would say take alook there first!!
I just created one that I use when pen teaching, it's at the following link. I think somewhere betweem Russ's instruction and my information you should be able to get started...Ask questions...we're here to help..
Take care,
Jim
Building On The Basics
Re: Don't discount the benefits of making pens
RussFairfield
>An amazing thing happens after you have turned a few pens - you become a better woodturner. Pens will teach you the benefits of a sharp tool, how the tools are used, and you might even learn to use a skew. They will teach you how wood is cut, tool control, dimensional accuracy, sanding and finishing; and all in short bites of time and at very little cost while making something useful. Learning these things will make you a better woodturner at everything you do.
Re: You don't need a drill press *LINK*
RussFairfield
>The drill press is a convenience, not a necessity for making pens. I show drilling the holes with both the lathe and the drill press on my website.
If you are looking for an excuse to buy another power tool, that is a different matter, and the drill press then becomes a requirement.
Making a wooden pen
HeatherA in Anchorage, AK
>I thought I had to have a drill press to make pens and got a nice used one but now I find that I kinda like drilling them on the lathe. I use a 50mm 4 jaw nova midi chuck to hold the blank and then a drill chuck in the tailstock for the drilling. Keep in mind that I am drilling one, maybe 2 blanks at a time. If I was doing many at a time, I would use the drill press.
Heather
