Detail Gouge
Detail Gouge
Detail Gouge
Steve in NC
>In several recent articles, I have seen several references to a custom made detail gouge. Some look they are made from square stock and some look like the starting point was a 3/8 spindle gouge. They are ground to a fine point. They look very useful. Can anyone tell me how to grind one. What do you start with. Can you use a Wolverine jig. Is so, what settings?
Thanks for your help
Re: Detail Gouge
Re: Detail Gouge
georgetroy
>You can use a spindle gouge, bowl gouge or even a small scraper. I took a class in 1986 from Rudy Osolnik at Arrowmount. At that time he introduce his spindle gouges and scrapers, they were all ground to a long sharp point. I still reply on mine for small spindles turnings and finishing off the bottom of bowls. I just freehand mine on the grinder even through I have a Wolverine setup. I these finishing grouges and scrapers in both 3/8" and 1/4". GT
Re: Detail Gouge
Keith Tompkins
Re: Detail Gouge
Keith Tompkins
>Hi Steve, commercial detail gouges differ from regular spindle gouges in the amount of steel, or mass, under the flute. The added material under the flute of a detail gouge can result in a smoother cut, especially when cutting a longer distance from the tool rest.
I use two different grinds for my own home-made detail gouges. One has an indentation created by the radius of an 8" grinding wheel where the flute would normally be. to create this, I secure the end of the handle in my grinding jig, and simple drop the tool down onto the wheel. Then, I secure the tool into my Wolverine jig, and grind the cutting edge, which continues in a long side grind, similar to the Ellsworth bowl grind. The result is a side grind, fluteless detail tool. I use round stock for this tool.
The other grind is simply a long bevel on one side of a piece of round stock....the resulting profile is perfectly round on the tip, great for detailing work on coves or bowl bases. It will also cut directly into end grain on spindle work, with the handle pointing straight into the work piece.
Re: Detail Gouge
Re: Detail Gouge
Kenny in Indep
>Hello, would you by chance have some pics of the above grinds, thanks for your time, Kenny
Re: Detail Gouge
Re: Detail Gouge
GaryG in MD
>Keith,
If I am reading your instructions correctly, your "first" "detail gouge" sounds like the tool posted by Ken Grunke on January 31, 2006. He called it (or compared it to) a "skewchigouge". Can you confirm that this is, indeed, the shape of the tool you are describing? I'm curious because I was about to make one like that, but then I read some negative comments about the Skewchigouge which have me rethinking it.
Secondly, could you go into a little more detail (no pun intended) on your second one. I'm afraid I can't quite picture it. Thanks.
Gary
Re: Detail Gouge
Re: Detail Gouge
Steve in NC
>Thanks for the info. Do you strat with a 3/8 diameter bar.
Re: Detail Gouge
Keith Tompkins
Re: Detail Gouge
Keith Tompkins
>Hi Guys, my camera has problems focusing, so I drew something up. The first drawing shows the flat "flute" created by the 8"wheel. then, the grind is formed using the wolverine jig, or in my case, a home-made version. You may have to experiment with the angle of the jig. This tool can be used like a regular detail gouge, except it is more forgiving; there is no flute to catch. Makes great coves, and works well inside goblets and boxes.
The second grind can be used flute-up to scrape details, or it will cut even though there is no bevel. It will also cut straight into end grain with the ground surface facing away from the cut.
Re: Detail Gouge
thanks
GaryG in MD
>Thanks Keith; very interesting. ...Gary
