Running Aground
Running Aground
Running Aground
Rick Davenport
>I'm going to plant a 1 micron, 1hp, 850cfm Penn State dust collector between my lathe and my bandsaw.
I have heard about grounding the hoses to prevent static electricity sparking.
Does anyone know exactly how to ground the hoses?
Thanks,
Rick Davenport
"Life shouldn't be dull."
Re: Running Aground
Re: Running Aground
Norm Smith in Nova Scotia
>Hi Rick,
I read somewhere a few years ago I read about the need to ground a dust collector system. Apparently , grounding your hoses etc. is a complete waste of time and money. I have had a 2 hp. collector with 8 piped outlets for many years and I am not grounded. Have you ever heard of one exploding?
It will be interesting to hear other comments.
Norm
Re: Running Aground
Re: Running Aground *LINK*
Mike Cunningham
>Rick,
INHO, there's is absolutely no reason to ground a DC system, particularly a home type system. There are no documented instances of explosion/combustion of these type systems, including those constructed of plastic. The possibility of occurence lies with industrial size systems and is limited.
Mine is plastic, no problems, including no instances of being shocked.
The link will provide a lot of info from someone who has researched this.
Bill Pentz
Re: Running Aground
Dick Hines
Re: Running Aground
Dick Hines
>Well there is always the first time. It's the old safer than sorry thing. I used the pipe with the wire in it and bounded everything to the dust collector, lathe and band saw. It only takes a few short piece of stranded wire and some wire nuts.
I don't if it makes it safter but I feel better about it. I know grain elevators will blow up from collected dust.
Re: Running Aground
Additionally
Mike Schwing from Md.
>It is impossible to ground an insulator! (plastic pipe/hose)
Listen to these guys - for fire hazard worries, there is plenty of evidence to support that it just isn't possible for the dust in your collector hoses to catch fire from a spark. However, sometimes those sparks can be quite annoying when the discharge surface is on your skin. In those cases, you can do a bit to mitigate the problem, but for safety/fire sake, that myth has been pretty thoroughly debunked. Still, there are plenty of people who will sell you the stuff for your peace of mind and their peace of wallet.
Re: Running Aground
Buy conductive hose from Flexhaust,
Eddie Pacheco; San Jose, Ca.
>If you really want to have ground the system. I have a Delta panel sander and using just the regular black flex ducting hose I was getting some serious 1" + arcs from it to me when I got between it and the sander. that's a lot of joules! I'd be reaching for the wood and my leg would contact the sander's frame and Bamm! I'd get a good zap. I got a length of ESD safe black flex hose from work and and used a piece of chain from the sander's frame to the hose and I don't get zapped anymore.
Running length of copper wire through your ducting is a waste and like the others say you can't ground an insulator.
Re: Running Aground
Here's a pic. of my setup.
>Here is a photo showing a length of chain tied to the sander and to the hose. I unclip the loop around the hose when I'm done with the sander.
Note; this only grounds the 6' length of this conductive hose only not the whole DC system as I go into a plactic coupling at either end of this hose.
With this setup I no longer have the hair raising and frequent zapping that I used to have with the standard black plastic flex hose.
I believe McMaster-Carr ahs this and it's a little pricey.
Re: Running Aground
Re: Here's a pic. of my setup.
Phil Joines
>I had the same problem with the same sander. I use a piece of wire with aligator clips on each end, one to the hose one to the sander's frame. End of problem.
Re: Running Aground
Re: Running Aground
>I just ran 12 gauge stranded wire through the pipes (and around some) and hoses and hooked the wire to my copper water pipe. I wasn't worried about explosions, just static. And for those who say it doesn't matter - the hose to the bandsaw was left ungrounded. When I have the hose to the bandsaw on, it looks like a chia pet while the grounded hose to the router doesn't. This only happens in the cold dry weather.
Re: Running Aground
Re: Running Aground
Rick Davenport
>Since it is seldom "dry" in the Pacific NW, I think I will set up without grounding the hoses.
If my hair stands on end or my home explodes, then and only then will I take action.
Thanks all for your advice.
Rick Davenport
