Drilling pen blanks
Drilling pen blanks
Drilling pen blanks
George Fitzpatrick - Springfield MA
>The last couple times I have turned pens, I ran into a problem. I cut the blanks to the appropriate size, put them in a self-centering drilling jig and start to drill. I clear the bit of debris three or four times, but right at the end of the blank, hear a pop, pull it out, and the blank has split. Has happened on cocobolo, bocote and teak. Have done probably 25 pens with this drill bit, and still seems to be sharp. Am I doing something wrong here or just bad luck?
geofitz13
Re: Drilling pen blanks
Scott Greaves in Blackfoot Idaho
>Hi George,
Well, bad luck is a part of it, because it won't happen every time, but this is a common problem, and I have a couple of suggestions for you. The first suggestion is to have a nice hard solid piece of wood under the blank to drill into. This will eliminate about 80% of the problem. The breaking occurrs when the bit is exiting the blank at the bottom, and the flute catches on the wood and torques it enough to crack the blank. The other solution, the one that eliminates the problem completely, is to cut your blank long, only drill deep enough to accomodate the brass tube, and then cut the blank off on the bandsaw exposing the hole.
I hope this helps!
Scott.
eaglesc
>I am going out on a limb here and offer the idea that the operative word here is "seems" to be sharp.
With all due respect to Scott.
I have NEVER used a back up piece when drilling blanks.
I use a home made "V" block in a machinst drill press vice or a "v" block from Grizzly in the same configuration.
No need for expensive toys.90 degrees to the table is 90 degrees no matter how it is set up.
I do however own and swear by The Drill Dr.
With that I KNOW my bits are sharp.
I can also make split points which are usually hard to find locally.In my experience they drill faster and cleaner than the expensive bits sold by suppliers brad points, Vortex....
I usualluy use HF bits.
Drilling for me can be tricky because I do a lot of segmented work.
I hate to put alot of time in a glue up and blow it out while drilling.
Since you mentioned teak(Has a high silica content) I would offer your bits are not as sharp as you might think they are.
Drilled with a HF Drill DR. sharpened bit but on a lathe in a BEall collet
eagle, what model...
Paul in Phoenix, AZ
>...Drill Dr. do you use. I've been thinking about getting one.
Don Tewell
>Wow, it never occured to me to use segemented turnings for pens. They look great.
Re: eagle, what model... *LINK*
eaglesc
>I started out with the $80.00 from the Blue Borg.
When it came time to change the wheel I called them and asked if they had an up-grade program. THEY DO!
I got the top of the line and at the time it was another $70 on top of the initial cone I bought. Actually not a bad deal because the refurb program was $39.95.
They have changed their line but as close as I can tell mine would be The 750.
It looks like either of the 2 higher priced ones will do split bits.
I have the one that will sharpen up to 3/4".
At the time I bought mine the $80 required you to send it back for wheel replacement. that has changed.
I realize a lot of serious woodworkers say only brad points bits are all they use and they can sharpen bits by eye, yada yada yada.
Good for them.I can sharpen my lathe tools by eye but not my drill bits
This thing has saved me more money in gas for not having to go buy sharp bits than it cost me and it works on Sunday afternoons too.
Drill Dr.
>Thanks for the input. My brother has a drill doctor, and I will try sharpening the bit. The ideas of using the extra block of wood, and drilling them long are both good ideas too. Will do some experimentation.
And those are GREAT looking pens!!!
geofitz13
Bill Turpin in WNC mountains
>Along with everything already said, I find that overheating causes a lot of blank damage. It seems to me that in very hard, oily woods too much heat causes the oil to vaporize, which creates an "oil steam explosion". I have an air blow gun with an extended snout. I blow a continuous stream of air at a point about 1/4" away from the drill's entrance point on the blank. This helps to clean off impacted oily sawdust and lowers the temperature of the bit. This method is the only successful method that has ever worked on redheart for me.
Bill in WNC mountains
>Hey Eagle!
Thanks for pointing out the "How sharp is sharp?" thing! I agree completely! And for those wondering, I use the Drill Doctor 750 and mostly Harbor Freight drill bits too! ;-)
Scott.
Scott
eaglesc
