sanding disks
sanding disks
sanding disks
larry tibbet
>anyone know of a good source for sanding discs or velcro backed paper?
thanks
Re: sanding disks
Re: sanding disks *LINK*
Allen Neighbors
>This is where I get mine. Klingspoor Gold is pretty good stuff.
Others have said Norton Gold is good, maybe someone will give you a location to buy that. They say you can get it at Wal-Mart, but not in this small town.
Hope this helps.
Allen
Klingspoors
Re: sanding disks
Re: sanding disks
Ray Thompson - Middletown,IN
>I just got some 2" disks from this place.
http://www.premierabrasive.com/Hook%20&%20Loop.pdf
You have to buy a minimum of 100 but they are only .13 ea.
Ray
Re: sanding disks
Re: sanding disks
gary s clarke
>Industrial Abrasives co.
Re: sanding disks
Re: sanding disks
Darryl Hansen
>Industrial Abrasives. $15 for a sheet 1 meter by a yard. Make your own about 9 cents. Make a punch from 2 or 3 inch pipe and hit with a hammer.
http://commerce.riverweb.com:8002/shop.html
Re: sanding disks
Sanding discs (link)
ob obrien In Pensacola
>Larry; I recently ran across a company called ASAP. They have a cloth backed selection of discs that are great. Iv'e tried all the makes of velcro discs and these don't load up or get hot. They have a different type of loop on a cloth backed disc that dosen't melt. Prices are also OK. The link is www.abrasivesasap.com. I don't have any affialation with the company just a satisfied user.
Re: sanding disks
Dick Hines
Re: sanding disks
Dick Hines
>Do a search for POackard tools. They have the White Rino disc. If you order them off theie sight by credit card you will have them in less than a week. They come in 1" , 2" and 3 ".
Re: sanding disks
Steven Antonucci
Seems like you'd get them for less than 0.09
Steve Antonucci
>My math on the 2" disks makes it about $0.04/each, assuming you have the pipe and grinder and don't assign value to your time.
at 36" x 39", there are about 1400 sq in of space. 2" circle consumes about 3 sq in, meaning you could get about 400 2" disks from the sheet. at $15, that's about 0.04 ea.
Now hammering out 400 disks to save a few dollars x 6 grits... hmmm... I'm getting tired just thinking about it! Don't suppose I'd do it all at once...
Steve
Re: sanding disks
Re: Seems like you'd get them for less than 0.09
Mark Kauder, Phenix City, AL
>Steve,
Look at my link below on how to cut them into 2" squares with a wornout BS blade. Russ convinced me years ago, that there is no practical difference beween the results that you get from a "Wavey" disk, and a square "disk". I cut mine all square, and if I absolutely need it round, like to get into a tight area, I have some cheap scissors next the the lathe, and just cut around the paper while it is on the mandrel/pad.
Basically, I am getting 350-400 disks for the price of 50 of the higher priced spread.
At these prices you really can "use the sandpaper like someone else is paying for it". I know that when I bought the other sandpaper, I tried to stretch it's use longer than I should.
Mark
Re: sanding disks
>I forgot to mention that I can cut an entire sheet of 350 disks in about 10 minutes.
I use 60, 100, 150, 220, 320, 400, 600.
I generally cut a few 3-4" disks as well.
Out club buys these sheets, I cut them into disks, and we sell them in bundles of 20 disks. We sell them for double the cost, and everyone is happy.
Mark
Re: sanding disks
Re: Sanding discs (link)
John H WIlliams
>OB,
I have had trouble getting ASAP's attention. Any suggestions? Thanks
Re: sanding disks
Brad Vietje
Great Idea, Mark
Brad Vietje
>This is another great way for clubs to band together and save $$$, like ordering Anchorseal and CA in quantities as a group purchase.
I have been using 6" Wurth disks made for autobody shops, and I get 7 - 2" disks using the hole saw/hammer method. I make just 7 of each at a time, so the labor isn't much at all -- in fact, I cut 6, and the 7th is the wavy-edged piece left in the middle. These cost me about $ 17.00 wholesale (I ordered them from my auto mechanic at his cost) for 100 6" rounds that produce 700 2" disks, or about 2.5 cents each.
Safe Spinning,
Brad Vietje
Newbury, VT
Re: sanding disks
Geeze Picky picky picky your right of course
Darryl Hansen
