Drill bit for Pen blanks?
mark4583
>Seems to be a wide variety of Drill bits for drilling pen blanks.
Which type of bit works well that you like?
I also picked up a Jet VS midi lathe with the Nova chuck today for a decent price of $400, from a local machine shop. Nice piece of equipment and whisper quite. Thanks for the recomendations for it.
Thanks
Re: Drill bit for Pen blanks?
Jim Shaver - Oakville, Ontario
>Hi Mark,
I drill blanks with brad points and bullet point bits, the ones recommended by the suppliers of the pen kits I buy. I do find that I like the bullet points better than the brad bits, but they both work well.
Take Care,
Jim
Russ Babbitt Jr.
>I second what Jim says. My first choice is bullet bits, especially when drilling synthetics or stabilized blanks, second choice brad points.
Scott Greaves, Blackfoot Idaho
>Hi Mark,
My first preference is a bullet bit. They just work better to keep the bit from drifting while you drill that deep hole. But bullet bits are hard to find in all the sizes you need. I have found that one of the best things I have invested in has been a nice big drill index from Harbor Freight. I got the 115 piece set when it was down around $30 something. These are just twist bits, but you can keep them sharp with a Drill Doctor. And it is nice to not have to worry about buying a special bit for every new kind of kit I try. So these are what I usually drill with unless I happen to have bought a bullet bit in that size. Good Luck!
Scott.
Depends
Phil Joines
>I like brad point for wood, pilot point for plastic and normal for aluminum and brass. The 9/32 works better for me for slimlines. Sometimes after drilling with a 7mm the tube didn't want to go all the way in.
Make sure you retract the bits often to clear the chips,if it gets cloged the blank will split. Also go very light when near the bottom to avoid splitting the blank if the bit grabs when breaking through. I set the depth guage on the DP at about a 1/4" below the end of the blank so I can see when it's getting close.
Bullet Bits, what supplier?
mark4583
>Ive seen these on one of the internet suppliers and I thought it was Penn but I cant seem to find them again.
Anyone know who carries them?
Thanks
Re: Bullet Bits, what supplier?
Denis Lalonde Oshawa, ON
>Craft Supplies USA did carry them, don't know if they still do ...
Denis
