Learned three things today.
Eddie Pacheco; San Jose, Ca.
>1. If you're retired, your wife is still working, and you decide to take your lathe outside to turn a few givaways and to catch a tan. Don't. Nancy came home for lunch and caught me having waaay too much of a nice day while she was stuck in a boring all day meeting.
2. Don't apply suntan lotion prior to turning dry wood. Shavings stick to it nicely.
3. Don't leave loaded digi cam out within easy reach....
Re: Learned three things today.
Looks Like
Ken Oakley-Sunny St. Cloud, Fla.
>1-Sunny St. Cloud, Fla.
2- Jogging will help.
3- My wood lathe
Jogging --- that's an impact sport, right?...:-)
Jennifer@Indy.USA
>Great picture Eddie....man I could sure use a dose of sunshine and some SPF 15! We're looking very pale in these parts about this time of year.
Sounds like a fantastic way to spend your day :)
Jen
Bill in Ga
>Eddie,
I liked the pic. Is your lathe a Rockwell? I have a Rockwell
wood and metal lath that looks very much like that.
Thanks, Jen.
>Unbeknown to me was that Nancy ahd taken this picture. I found it when I was getting ready to upload the pic. of my work.
I did read a little of your initial posts on that Kerosene heater and at the time I wasn't sure why it was such a big deal. Then I read where someone else had the same heater and it took him several hrs. to get to 56 degrees. I decided to check the weather in Indy and that's when the importance of a shop heater struck me. It's rare when we get into the 30's here.
It looks like you and Winston will be doing some studio insulating this summer.
Take care.
It's an Atlas 1722, 12" lathe
>I bought it for $100 5 yrs ago from an older guy that was starting to get rid of some of his woodworking tools. It came with a bunch of stuff and some woodturning tools so I thought I was set. Little did I know that I would multiply that cost many times over in "must have" accessories. This has been a very good learning lathe for me.
Re: It's an Atlas 1722, 12" lathe
Bill in Ga
>Mine came to me free by way of my son's father-in law doing some clean up. I didn't have a lathe at the time so I took it and made a frame for it and hookup the motor the same as yours. It came with a
motor mount that was mounted at the back of the lathe head. I didn't like that position so changed it. The biggest problem I had with it was that even the slowest speed was faster than I needed for sanding ,etc.
>Bill, you're right about the slow speed being too fast for sanding. That means we'll get better at sharpening and using our turning tools to avoid sanding, right?
I added two extension springs from the hinged motor mount to the frame to minimize the motor whip when the lathe is started. These helped a lot.
A good thing about this motor setup is that if you have a bad catch the drive belt will often slip first and you don't launch your turning blank.
My wife has been asking me for larger dia. platters, but I told her I was at the limit of the lathe. She has now started to ask me when I am going to get another larger lathe. Cool.....
