Abralon or Micro Mesh
Dave Winters
>I'm sure these have been discussed ad nauseum, but which do you like, if you've tried both, especially for polyester resin? Abralon comes in 3" discs, right? What about MM?
Sources/prices?
Thanks in advance!
Re: Abralon or Micro Mesh
I Use Both *LINK*
Jim Shaver - Oakville, Ontario
>Hi Dave,
Well I use both actually. What I use them for is finishing the surface of my pens. Most of my materials to finish are either stabilized wood or man made materials that will both take a fine polishing well when prepared and refined with these microabrasives.
I have found over time and experience with what I use that I combine them for a process that yield me very good results.
I use the Abralon pads, 500-1000-2000-4000 as my first finishing process when wet sanding, using water(cleaning with a paper towl between micro grits). Then I switch to Micromesh, -6000-8000-12000, again all wet sanded with water. I then depending on the material either use a plastic scratch remover or go to a friction polish or straight wax. I do not know if the Abralon and MM grading is complimentry, but I have looked carefully at the scratch patterns they leave and this is the best fit for my work.
My process was recently published in the on line magazine More Woodturning....I guess that's a gloat eh...anyway, it works well for me and I hope that helps.
I am sure other turners have their own applications for both so this should be a good thread.
Take care,
Jim
More Woodturning
Tony - Memphis
>I buy those MM kits at Woodcraft with the small patches. I love the stuff. It lasts for quite a while and I wash it now and then. One note is that you can melt the MM and leave dark streaks if you aren't careful. I just ordered a new MM kit...I splashed varnish all over an almost new set a while back...bummer.
Tony
Re: I Use Both
Bruce Wiseman
>Hi Jim,
Congrats on your article! You have a great deal of knowledge and have always been willing to share it. Between you and Jennifer, I now know two published woodturners. Sometimes vicarious pleasure is my only pleasure. BTW, thanks for your gift via Jenn, totally unexpected but very welcomed.
Bruce
Re: I Use Both
>Hi Bruce,
Thanks for your kind comment. I know Jen's a famous wood artist, picture in a magazine and everything....I just make pens.
I am happy to hear that you have that Ribbon, your contribution to PFCPK has been much appreciated.
take care,
Jim
Re: Abralon or Micro Mesh *LINK*
eaglesc
>I haven't used abralon because I am pleased using Klingspor Gold up to 400 grit and then changing over to MM.
The best price I have seen for MM is at International violin.
They seem to have changed their site but the last time I bought it the sheets were 6x12.
Klingspors now carries it also.
international Violin
Steve Worcester
>I have used and sold both for quite some time so I guess I will pipe in here.
There are several types of micro mesh product, you can look at them at www.micro-surface.com . They don't even share the same grit ratings across their own product, or the "standard" grit rating systems. They have a different system for each product.
Micro-mesh does indeed go much finer. Way past where Abralon goes. Personally, I find the micro-mesh product too soft for power sanding except when using a lubricant, such as wet sanding. They use a softer bonding agent to bind the grit to the backing. If you are turning (especially exotics) and generate too much heat, you will melt the surface of the disk to the wood. I do use it wet for glass though too, but the abrasive itself isn't meant for that (not hard enough).
Now, Abralon isn't perfect either. It works well in a dry or wet environment, unless you are sanding with solvents. There is a tendency for the grit to debond on the edges if you roll over hard edges, such as in sanding the edges of a square turning. Abralon is only available in 180, 360, 500, 1000, 2000, 4000. You actually can jump through them, but not skipping, with no issues. I do like the sponge backing of the Abralon for wet sanding, at low speed it acts as a reserve, at high speeds, a shower.
Both Abralon and Micro-Mesh leave a different scratch pattern that traditional sandpaper, and for the finish I like, I still need to buff when done. I (personally) feel you get a clearer finish (on a film finish) when all is said and done by buffing with carnauba in the end. The same may not hold true for exotics that you are sanding up high and using it's own natural oils instead of a hand applied finish.
I do have a grit chart you can download from my website that compares all the major grit systems based on info gathered from Microsurface and other sites.
http://www.turningwood.com/faq.htm
Steve Worcester
www.turningwood.com
GaryG in MD
>Steve,
Thanks for the grit comparison chart. That's helpful. Can you tell me where the Abralon numbers fit in there? Are they the same as one of the other sanding grits or something yet different? TIA.
Gary
Steve Worcester
>Sure. Abralon uses the P-Grit system (Fepa/Euro)
Finally!
GaryG in MD
>Thanks a lot Steve! I've looked all over the web and haven't been able to get that simple answer. That's what I needed to know -- now it all makes sense. Cheers, Gary
Thank You
>Thanks Steve,
I guess my eyes have been seeing just as you describe. I have combined the two to get my finishes down to a surface condition ready for polish. Would you make any recommmendations to my process,
I do the following
All wet sanded with water
Abralon 500-1000-2000-4000, Micromesh 6000-8000-12000...then a plastic scratch remover (Novus 2).
Thanks,
Jim
Re: Thank You
Steve Worcester
>how are you applying (using) the Novus?
Steve Worcester
www.turningwood.com
Re: Thank You
RussFairfield
>Jim,
I use Brasso on the plastics. It is a fine polish grit, and I can get a higher shine faster than with any of the plastic polishes.
