Silver Solder
CCollier, Pasadena, Tx
>For those of you that make some of your tools,can you tell me which of the many silver solders do you use to solder the high speed steel to the shank.
Thanks for your help.
Silver Solder
Re: Silver Solder
Don Derry
>Hi,
I silver solder a lot of stuff. The secret is to use a good appropriate flux with a lot of heat. I use Harris brand Safety-Silv #56 along with their Stay-Silv White Brazing Flux. This is a good general purpose system that will join and hold almost anything. I believe it is 45% silver.
don derry
Re: Silver Solder
>I don't know what the brand is but I buy mine from www.riogrande.com They come in 3 melting temperatures, hard, medium and soft. For your purpose it doesn't matter which one. As Don mentioned you need flux to do the job right.
Re: Silver Solder
>Thanks for the info. RioGrande catalogue is on the way.
Re: Silver Solder *LINK*
Bill Turpin in WNC mountains
>There are several WC articles on silver soldering. Here is a link to one I helped author.
Bill in WNC mountains
WC soldering article
Re: Silver Solder
Phil Joines
>I get it at the local welding supply shop along with the flux. They sell it by the ounce.
