Re: System Three Epoxy-How about T-88? instead
Bill Grumbine (Kutztown PA)
>Hi Jill
Epoxy consists of two parts, the resin and the hardener. The resin for most uses is the same stuff, while it is the hardener that varies. Different hardeners are formulated to allow the epoxy to cure at different rates. Ambient temperature affects the rate of cure as well, and the various rates specified for each hardener are specified for a particular temperature. For example, the various rates you mention may be valid at 70 deg (I don't know if that is the actual temp, I am just making up numbers for illustration).
if you are working in a very hot environment, and you need time to assemble everything, or coat everything with the epoxy you are using, then you would choose a slow setting hardener. If you are working in a colder environment, you might want a faster setting hardener. Application of heat by shining an incandescent light on the piece can accelerate the cure. Generally the slower the set time, the stronger the bond. The differences between bond strengths for most of us are not going to be an issue, although as you are finding out, the fast set 5 minute stuff is not getting as hard as you would like. You should be able to buy a slower setting hardener and mix it with the resin you already have. So, instead of setting in 5 minutes, it may take 30 minutes. If you live in PA and turn the heat in the shop down to 40 deg at night like I do, it will take all night to set. But it will set properly, as long as you keep your mixing ratio accurate, which most of the time is two parts resin to one part hardener.
I hope this makes my first answer a little clearer for you, but if not, let me know. I learned all this stuff back in the late 90s when I was building a boat, and went through about five gallons of epoxy.
Bill
