Epoxy Tip
Epoxy Tip
Epoxy Tip
Mike in Fort Walton Beach, FL
>I forgot to post this with my question about epoxy earlier but I wanted to pass on a little trick we use at work when we use epoxy to rebuild circuit cards. If you have a turning that you want to add epoxy to but it is a hole that goes clear through (from an inclusion or whatever), you can cut a piece of plastic coffee can lid in whatever shape you need, tape it to the adjacent wood to keep it inside the turning, then fill how you choose. The epoxy won't stick to the plastic at all and it's flexible so you can make it fit any shap you might need. We also sometimes use plastic teflon sheets cut to fit if available. I thought of this when I saw that a turner used duct tape to create a support backing for burl bowls and hollow forms before filling with the epoxy. It seems to me there is probably a lot of effort involved in removing the sticky back duct tape and adhesive from the turning. I hope this helps and as it is my first time posting a tip so feedback is always great. Let me know if any part of the process is unclear.
Thanks for listening,
Mike in FT. Walton Beach, FL
Re: Epoxy Tip
Re: Epoxy Tip
Norm Smith in Nova Scotia
>Great tip Mike, I use a baloon for hollow forms but will give your idea a try in bowls, etc.
Norm
Re: Epoxy Tip
Re: Epoxy Tip
>Hey Norm, the balloon idea never even crossed my mind. Great idea! I'll keep that mind when I get to the level of trying hollow forms.
Mike
Re: Epoxy Tip
Re: I used a duck egg once as a form.
Al Crandall (NE of Indy)
>An engine shroud on a friends home built plane needed clearance for a valve lifter. He came to me for help. I cut a hole where the wear was showing on the inside and shaped it to an aerodynamic shape (egg shaped). I covered a duck egg with saran wrap, (which is used extensively in plane building because epoxies won't stick to it), and held it in place from the inside of the cowling with duct tape. I glassed over the egg, removed it and glassed the inside, and I was done. The finished glass and epoxy "fairing" was a big hit with the owner. He had a great guffaw over my choice of mold shape, but a chicken egg would have nearly fit through the hole and extended too far into the slip stream. Anyway, think saran wrap when working with epoxy.
Re: Epoxy Tip
>Clear stapping tape works well, too. Epoxy won't stick to it, and it doesn't leave sticky adhesive like duct tape.
