We value your privacy.
>I have been using the white backside of a 36" x 45" poster, made of some type of plastic sheet, that works great for a photo backdrop for smaller turnings. What I really like about it is it's washability--I can take pics of greasy old tools for selling on ebay, then wipe it off and take nice shots of my woodturnings with no smears. My educated guess is it's a vinyl material, or PVC, and I've googled extensively looking for a source of larger sheets that I might be able to buy locally or order via the internet. A 4 x 8 sheet would be ideal. Even more ideal would be such a sheet with white on one side, and black on the other, for less than $25.00. Any leads?
>4 x 8 sheet? Does it have to be in one piece? I have a lot of film stock which is a laminate made with a white opaque layer. I could send you a piece that is 2' wide and however long you want it. You could cut it into 8' lengths (or longer) and mount it on a frame. I could see if I could scrounge some wider widths if you want. It wouldn't be PVC. If you want to make it somewhat matte, you'd have to spray it with a dulling spray. As is, it is somewhat shiny. If you are interested, drop me a email.
>Ken The only thing I've found is Formica or some other plastic laminate but it ain't $25. I have another photographer friend who uses plastic sheets that he gets from a plastics supplier but they are as expensive or more so than plastic laminate.
Window shades work if you get good quality ones. The cheap ones show the roll up marks so they don't work very well.
>I think the stuff I'm referring to is used for printing large bannere, like for parades and such. It's quite thin and flexible, about the same thickness as thin card stock, maybe even less.
At my regional home construction supply outfit, (Menards), a 4 X 8 sheet of white wall covering is available for about $12. It's thin and flexible, and white, but is textured on one side. If it weren't for that, it would be ideal. If I could find a sheet of the same stuff but smooth on both sides, then I can roll black printer's ink on one side. I have a big tube of black ink from an old Gestetner printer that I can use for this.
My situation is such that I have the space to set up a large backdrop, but I can't leave it in place. I want something I can roll up into a tube of about 3" dia. and tuck away in a closet. I don't need a photo booth setup, just enough floor space where I can choose to have the backdrop lay flat or be curved upwards for a seamless background. Hence the 4 x 8 size. I'll lay it flat on the floor, or curve up the back end with a clothspin or springclamp to a chair or cardboard box.
The material you are looking for is called Sintra which is a PVC material.. It comes very thin but I don't think it can be rolled quite as small as you want. Sintra is used alot in the silk screen industry and is available from Midwest Sign & Screen Printing Supply Co. (www.midwestsign.com)
A very inexpensive option is to get some cheap vinyl flooring from the big box store and paint the backside with a flat latex paint. This will roll up on a 3" core very nicely.
Finally, check the Setshop in NYC (www.setshop.com) for tons of different backdrop materials for table top photography.
These are the main things we use in commercial catalog photography along with Formica.
Do you want to buy something or are you looking for something free?
We occasionally get large posters printed (up to 10' across) and some are printed on plastic material that is smooth white on one side and a more matte white on the other. I never looked at it too closely but I could - I salvaged some about 8' across (printed on one side). You should be able to get blank sheets of that or many other materials from a large professional print house but it may be expensive for a big piece.
We also have some printers in-house that print on rolls 4' wide. I salvaged some end rolls that were going into the trash. This looks more like inkjet printer paper, probably since that's what it is. I thought these (and the plastic mentioned above) were too white and shiny for photo backdrops so I never even tried them. You might also find ends of rolls like this at a print house, and they might give them away, but they probably won't be longer than 3-4' or so.
I also saved some sheets of drafting mylar from 25 years ago which I suspect would make a good backdrop since the material is both matte-surfaced and translucent and could be easily backed up with a variety of materials and easily backlighted. This used to be available in huge sheets but I'm not even sure where to look for it now.
What size of pieces are you looking for? Where do you live?
As for inking the back with a roller, I'd be concerned about the ink cracking, but I guess it would depend on the type of ink, the thickness, flexibility, and how well it bonded to the plastic.
>John, window shades sound like a good idea, if I can't find the raw material that they are made of. I'd like something at least 6 ft long,as I prefer laying the backdrop flat instead of curving it up. A 4 x 8 ft. size would be ideal so the edges don't show either on the sides or back edge. Thanks.
>I could use the material you first mentioned, printed on one side--that side I could roll with black ink. I'd like something at least 6 ft long, and the wider than 2 ft the better. I'd be willing to pay probably 50 cents a square ft. for it, in like new condition.
I live in SW Wisconsin, about halfway between La Crosse and Madison.
>Ron, the piece I have is quite thin and flexible, seems like the same material used for window shades but is smooth on both sides, no texture. Sintra is more of a foam like material, and thicker. I've seen 4 x 8 sheets of wall or floor covering for only $12 at a big box store, only an hour's drive from me so I'll have to check it out next time I go up there.I think it was about 1 mm thick, but quite flexible.
Sounds like what you were using is a polyethelene banner stock for ink jet printing. We get it in 36" and 44" x50' rolls for printing banners with our large inkjet printer. Check lexjet.com if you are interested in that kind of material. It only comes in white. If you call them they might send you a short sample roll.
Midwest Sign sells blank banner material but you might have to buy a large roll and that could get expensive. That material does come in colors.
>I'll try to call one shop we use and ask about the cost. If it's reasonable, I'll try to get a sample and/or the name of the product. (You might be able to get it locally) I don't have a clue about the material cost, just the printed cost - about $25 per square foot (!) if I remember correctly, but I deal with the artwork, not the money end of the job.
>I have a Unisource (paper) price list on my desk(top). They list a roll of Poly Poster Satin, 8 mil, 36" x 16.4' @ $10.37 CDN. It is available in wider widths, but much longer lenghts eg. 60" x 100' @ $145.50 CDN. This is a Kodak product for inkjet printing and possibly is available on-line?
>lexjet.com has a roll of 15 mil SCRIM VINYL, called THRIFTYBANNER--
$130 for a roll 60" wide and 40 feet long. That's 65 cents a square foot. Exactly what I'd like, but I'm certainly not gonna buy a whole roll. At least now I know what I'm looking for, maybe I can find a local print shop that will let me have some scraps, or smaller lengths to buy. Thanks, Ron.
