THE WOODRAT IS BACK!
Speaking of buttoning up a shop
Carole Valentine
>My cousin was telling me about some stuff that a guy put in the ceiling of his garage. It is apparently a white skinned foam board that acts as both ceiling and insulation. It is pressed onto metal studs in the joists and then a "cap" is put over the stud that locks it in place? Has anyone seen this stuff? Sounds like something I might be able to do alone since foam is so much lighter than drywall or ply. ANY sort of ceiling would make all the difference in the world in my shop and I can't afford to hire anyone to do it.
Re: Speaking of buttoning up a shop
Gary in Zirconia, NC
>I would be careful with that. Most foam insulations are made to be covered with drywall for fire reasons. Check with the manufacturer or distributor first. That would work good for insulation though. I know people who have put it in their garage and then dry walled over it.
Sam Dean
>Carole,
It sounds a lot like a standard acoustical suspended ceiling, like you would usually see in commercial buildings. Most of the ceiling tiles are made of compressed fiberglass insulation and have a decorative 'skin' that covers one side (the side you see from below). You would need to install tracks and rails (really easy when you get the hang of it), then just drop the tiles into place. All parts are available at just about any major home improvement store.
Thanks,
Sam
>Second the idea of a suspended ceiling. They are relatively easy to install. You could use the 2' x 2' grids and drop it some 2' x 2' fluorescent fixtures.
